Dibs-h
Austin Branson":22yhtyrh said:Dibs-h":22yhtyrh said:As I stated earlier - I don't see any issues with fully bedded DG units in timber frames as long as they are done correctly, using quality materials.
I appreciate folk may feel differently.
Dibs
Dibs, sorry to be so stupid, but what do you mean by that? What is 'fully bedded'?
Austin
Austin
If you click on the following link,
http://www.hodgsonsealants.com/techlibdoc.php?p=5
and then on "View Specification Clause" you should get a PDF. In essence "fully bedded" is the edge of the unit sat on rubber blocks on underneath the bottom edge (and ones on the side if an opener) and the void between the unit and frame, fully filled with sealant.
The down as above - should fill in the gaps, so to speak. If not ask. :wink:
HIH
Dibs
