defsdoor":2pr7suoz said:
I haven't misquoted anything. I asked you a straightforward question - you are advocating that changing the current page margins to relative widths would be a mistake and quoting "industry standard design" as your argument.
<SNIP>
I said no such thing.
You sarcastically suggested that the comments i had made in an earlier post were "my humble opinion". I responded by saying that the points I had made were well known and researched points and form industry standard. At no point whatsoever did I suggest that the forum design IS industry standard. That is your misquote to further an argument.
In your last two posts you have expanded your comments to talk about relative widths, choice and scaleability. Your initial posts did not say that - you simply demonstrated screen shots with excessive margins compared to no margins. I responded to say that forcing full width use of the window for text makes it less readable and would be a mistake.
At no point have I suggested that the forum is in anyway ideal - if you read my musings post you'll see that I specifically stayed away from making a comment on whether it was good or not, to stay away from this kind of rant. Instead I attempted to discuss the choices and decisions that need to be made in design and why they are made. Partly to order my own thoughts partly because i had been reading a lot of complaints here from people who might not understand why certain changes have been made.
Now I happen to agree with a number of the comments you have made about flexibility, choice and particularly vertical screen space. But those comments were not what you made in the posts I responded to.
However as an IT professional who by your own admission ...
I personally can scan a screen of text very quickly so I like to see as much of it as possible. It means I don't have to scroll so often and, when programming, for example, get a lot more done - my text window is 250+ characters wide and 100+ tall (split in to multiple panes). I hate bog roll sites where you have to scroll for what seems like forever to get to the point.
Congratulations on your exceptional visual acuity ... but this is not typical across the population nor is it I suggest typical of the membership of this forum. There is a huge difference between the layout of a screen required to code and one for readability of text. What you have expressed there is YOUR preference, not what is remotely accepted as good practice for readability of text for a cross section of the population.
I have worked in the past on triple screen systems with complex schematics, engineering drawings and multiple associated written documents running concurrently. There is no way on earth I would suggest that thats a suitable visual format for the casual browsing and readability that a predominantly hobby related website designed to encourage contributions and social interaction.
