Philly
Hi All
Sorry about the title :lol:
I have been a little unhappy with the performance of my Clifton 4 1/2 recently. I have been tweaking the blade, ensuring that wasn't the problem, but checked the sole last night with a reliable straight edge and feeler gauges. I found a hollow of about 0.0015 (which is within stated tolerence for Clifton planes) in middle of the sole, so thought I would have a go at lapping the sole.
I set up my piece of float glass on my workbench and then checked with the straight edge to ensure that the surface was flat. (at least as far as I could measure) It was definitely flatter than the sole of the plane, so out came the 100grit wet and dry for some lap action. Here's how it looked after 10 strokes....
You can obviously see where it was hollow. I spent a further 3 minutes carefully removing the rest of the marks, making sure I kept even pressure on the plane. ( I held it with both hand either side of the frog) Here's how it came up...
I cleaned it up, polished it out with 1500 grit wet and dry and applied some oil. Spent some time taking test cuts and there is a definite improvement (when taking very fine sub 2 thou shavings). I won't bore you with curly shaving shots, but it certainly made an appreciable difference.
I'm not a member of the "flat sole society" as in practise this is difficult to achieve, but this simple procedure has definitely mproved the performance of my plane. If you notice your favorite plane is not performing as it once did, maybe this could be what you are looking for?
Philly![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![lap2.jpg](https://proxy.imagearchive.com/4dd/4dd6635a10410c47f4c3a1cfa7894e1b.jpg)
![lap3.jpg](https://proxy.imagearchive.com/d1a/d1a7d40a57f900fb387079f09194a31a.jpg)
Philly
