Don't use plumbing flux, it is acidic and can eat into the copper wires. Electrical flux like rosin is not acidic.plumbing flux now
Which is of course exactly how it works very effectively on copper pipe.I have used this technique on stubborn joints for years without issues. You certainly do have to make sure you use it very sparigly, and clean properly afterwards, otherwise yes you would have issues in future. But for instances where all normal techniques have not worked, this has never failed me. If access for cleaning afterwards is an issue then you can use it as a preparation beforehand. I also find that the moern lead free solders are nothing like as effective, unless everything is spotless. Ì treasuure a stock of old lead solder for those more challenging situationsDon't use plumbing flux, it is acidic and can eat into the copper wires. Electrical flux like rosin is not acidic.
Have seen it for elecrical use, didnt know you could still get it for plumbing. Fortunately i still have enough rolls of the good old stuff to see me out!You can still buy lead based solder for both plumbing and electrical / electronic's . For avionics, medical and mil specs then I believe you can only use lead based solder which does say something for lead free!
I find if it’s clean and fluxed it will flow I usually used cored solder on wiring ( solder with flex inside) good luckIve a question about soldering, in case anyones an expert... Im trying to repair some failed electrical joints in some speaker drivers. They have two delicate wires that go into the voice coil under the central dust cap/dome, but they have perished through oxidation i think in damp storage.
I want to solder a new connection to these wires that go into the voice coil, but i cannot for the life of me get any solder to stick. I have gently abraded with a stanley blade, fine sand paper, and heat to try and get rid of any possible coating, to no avail. Using flux and tried a couple of types of bog standard solder with a cheapo soldering iron.
Im stumped. If i can just make a reliable electrical connection (has to withstand being wobbled vigorously at many frequencies) i think i can salvage these drivers and they are decent, full recone kits are laborious and expensive so it would be great to avoid that. So im hoping i just need bettert solder/flux/iron?
Yes with plumbing you can use lead but not on potable water supplies. What some plumbers do is to roll lead solder onto the spool saying lead free. We have had lead solder for decades, I cannot recal any deaths as a direct result of plunbers using lead solder, there are still a lot of houses with lead pipes and the only joint failures I have had, have been with lead free. You are probably inhaling more toxins and such just by walking through London than the lead used in pipework has delivered to the population.didnt know you could still get it for plumbing
Yes, sill have a lead main here. And at my dads cottage he still has a number of pipes with the big egg shaped lead joints. He's nearly 100 and still going strong. As for air pollution I seem to recall reading somwhere that if you drive a modern low emission, cat etc car through some cities the air coming out of the exhaust pipe can be cleaner than the stuff going inYes with plumbing you can use lead but not on potable water supplies. What some plumbers do is to roll lead solder onto the spool saying lead free. We have had lead solder for decades, I cannot recal any deaths as a direct result of plunbers using lead solder, there are still a lot of houses with lead pipes and the only joint failures I have had, have been with lead free. You are probably inhaling more toxins and such just by walking through London than the lead used in pipework has delivered to the population.
And you need different flux for silver solder. The borax type and a lot of heat from a gas torch. I don’t recommend using it.You won't solder silver solder with an iron.
Maybe you could crimp a tiny ferrel to the end of the wire and the solderThanks everyone! Have ordered a nice new iron and ive got some plumbing flux now and will give all these things a go and report back.
Correction - then solderMaybe you could crimp a tiny ferrel to the end of the wire and the solder
Hello,Ive a question about soldering, in case anyones an expert... Im trying to repair some failed electrical joints in some speaker drivers. They have two delicate wires that go into the voice coil under the central dust cap/dome, but they have perished through oxidation i think in damp storage.
Yes cleaning any residue is important, so it doesnt carry on working afterwards. So needs to be used vary sparingly and neutralised/cleaned with a dampened q tip or contact cleaner. I certainly wouldnt advocate using it routinely, but when you are in that last chance saloon situation, when the next move is to have to bin the thing, its well worth a try. Has got me out of a hole on many occasions. It is also useful for soldering dissimilar metals. I do regularly use it for soldering brass curb pins onto steel regulator arms in pocket watches. Have tried various specialist products, but have never found anything else that does the job as well.As has been said just be aware plumbing flux tends to be rather strong and can be both water soluble (easy clean) and not so easy!
It will hopefully achieve what you want but should be neutralised or cleaned off to prevent future damage to the surrounding cone.
Wire corrosion is the formation of an oxide, flux does not REMOVE the oxide.I have often found that plumbing flux overcomes this sort of issue. Seems to be much more powerful. Just smear a tiny blob, maybe a mm round or less on the surface then use your regular iron. I would advise you clean thoroughly afterwards as its powerful stuff and if you leave any residue behind it will eat its way through your delicate wiring.
