wobblycogs":2i8tb3rv said:
It's unlikely that everywhere in Europe will all have a peak demand at exactly the same time so some power trading would sort out any problems.
Peak demand often occurs at
exactly the same moment over large parts of the planet, because of the televising of international sporting events. The classic examples are the Superbowl and the World Cup final. The moment the whistle goes for half time, several tens of millions of kettles go on.
The joke in the BBC about Dinorwig was that it was built to counteract the commercial breaks in Corrie. Back in the late 1970s I remember seeing the demand graphs that showed this. This type of synchronised demand is what pumped storage excels at covering. IIRC, Dinorwig can come on stream within seven seconds if the turbines are already spinning, and 16 seconds to full output (1800MW), although I think it's only got less than an hour at full output**.
I would have said probably the most dangerous nuclear plant in the UK is Dounreay as it is getting old and was designed for nuclear experimentation at a time when we didn't fully understand the risks. Decommissioning it is certainly going to be a real challenge. It's a close call between that and Windscale though.
I think it's already in hand. One thing is that the plant's capacity is considerably smaller than later 'production' reactors. As I hinted earlier, we've already decommissioned and fully cleaned-up after what was probably the riskiest one of all. It can be done.
You've got to admit that setting fire to a reactor is the mother and father of all bad days at work
When the CEGB HQ was in Bristol in the 1980s, one of my friends worked as a metallurgist on the 'local' nuclear stations (apparently radioactive particles do funny things to the physical properties of metals over time). He was a great fan of our AGR (Advanced Gas-cooled Reactor) design, on the basis that the half-life of the radioactive products from the CO2 primary coolant is very short (tens of days). Thus, in the event of a catastrophic primary containment leak, one stratagem is simply to leave the secondary containment sealed and come back in a few months. This is in contrast to the US PWR designs, now prevalent, that are not 'inherently safe*' in the same way. Or so I was told...
I was also told that Magnox had similar safety advantages, but I believe both it and AGR development were dropped because of their higher costs compared to PWR and derivatives. There is presently talk of a new class of Thorium fuel-cycle reactor, which might be both cheaper on fuel and safer.
If you're interested,
http://www.angelfire.com/extreme4/kiddofspeed/chapter1.html has a lot of pictures of present-day Chernobyl.
Cheers,
E.
*for rather odd values of 'safe', admittedly!
**I checked Wikipedia before writing this. I think it's article is a little disingenuous in that the 6 hours it claims probably isn't at full output. I'm fairly certain I was quoted a 30 mins full load run time and 7sec warm start by an engineer on a visit in the early 1990s, but I may be wrong. My memory plays tricks on me at the moment.
