Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
misterfish":2n6dnw2r said:As the OP (from over 18 months ago) I'll also add our update.
When we saw the Feed in Tariff rates for PV we also thought it might be worth pursuing, so we started investigating the feasibility/options back in March. This is not a DIY option but has to be installed by approved contractors using approved equipment so it isn't a cheap 'on a whim' purchase.
Anyway, we finally ended up with a 3.25KW notional power system that was installed in August. The actual maximum output of mains power we get is 90% at just over 2.8KW - so far we have generated just over 500kW.
Do you mean 500kWh (kilowatt-hours)? (kilowatts are a rate of energy production or use, not a quantity).
Assuming kWh, and that 45 days have elapsed since installation (mid- August to mid- September plus two weeks and a bit), that gives an average power output of less than 0.5kW. Assuming you can only generate effectively for 8hours/day, it rises to roughly 1.5kW when it's working. I think the figure you're measuring is the peak output.
I've got a few questions:
1. Do you have a large battery array and an inverter, so that you can store what you produce?
2. Do you 'sell' to the grid, if so at what rate? Are you required to remit the 5%VAT to the government?
3. How much did the installation cost, and was there any sort of guarantee on output and longevity?
I have 8sqm of water heating panels on our roof. It's usable even in the depths of winter (when the sun is shining), but I can't store sufficient hot water to take full advantage of it.
Was it cost effective for us? That's hard to answer because the energy produced is very hard to measure. It cost around £4,000 to install, but some elements of the system were already in place (boiler and tank in proximity to the roof). We also scheduled the work to coincide with scaffolding being up, so that cost was spread. Our gas bills are very small in the summer (about a fivefold difference from winter quarter's usage), but it's not quite enough at present to cover the morning household dash to the showers. It is, however, long-lived, very simple in technology terms, and very low maintenance. I intend to 'upgrade' it with an additional water tank when I can, part of the delay is cost, part because I can't work out a suitable plumbing arrangement at the moment.
