Solar panels still worth it?
Almost all comments say payback is 10 or so plus years. If you intend to move house in that time or if you are old and might not live that long or if the selling back price falls really low imo it's just not worth it.
As regards green credentials imo whatever we do in the UK to reduce emissions the entire UK savings I have heard are negated in a couple of hours by the amount of emissions from China and possibly USA especially as the new government appears not interested in the subject.
Well that's my current thinking
If your neighbour 💩 in the street does that make it right for you too as well?
We have 4KWp of solar panels which came with this house when we bought it. We had to replace the inverter about a year later as it packed up - cost £660. We added 15KWh of batteries to the system a little over a year ago and also moved across to Octopus Agile. Our house is oil heated, but with hydronic underfloor in most of it.
The Solar is on a relatively old FIT. We get 22.8p per KWh for everything we GENERATE plus 7.14p per KWh deemed export on half of what we GENERATE. What we try to do is use as much as we possibly can as we still get paid even if we consume it. Due to where we live and the orientation of the panels, this gives us about 6 to 7 hundred pounds a year of income plus, by storing much of it in the battery, it means that we don't need to buy that electricity.
I've looked into the benefits of a heat pump countless times and the big thing that puts me off is the quality of the system design and installation capability. There are far too many installers who have spent their lives installing large gas boilers and are now trying to do the same with heat pumps. General accepted practice is to install a heat pump roughly equivalent to the heat loss of the house and not much larger than it. So, if our oil boiler dies, we will only look at a heat pump then. let's hope that there is an equivalent of the BUS when the time comes. Get the SCOP wrong and a heat pump becomes a very expensive proposition.
So, is solar worth it? For us, if your system allows you to store and load shift what you generate then it may be a reasonable proposition. It really isn't a decent proposition if your motivation is to use what you can at the point of generation and export (for reward) the rest. It's almost a given that many of the export tariffs are going to get more and more mean as time passes, especially as the UK has an excess of green power at some times and a huge deficit at others (especially in the winter).
It's really hard to measure a payback time for us because, as with our previous house, we changed the way that we used power based upon the system we had. In our old house we tried to use power when the sun shone (as we didn't have batteries) and were careful what we used at other times. In this house, now, it's all about acquiring the energy cheaply, be it via solar or at low cost periods with Octopus Agile, storing it and using it as and when needed. Home Assistant automations also help massively with that.
I don't think I would ever consider buying solar without a method of load shift (such as a battery or a suitable EV).
Huge amount of money, not a lot of pay back if any, expensive maintenance with risk of major breakdown. But most of all it all depends on reliable infrastructure of electricity supply and affordable back up services.
That is one of the big downsides to all this newer technology and complexity is fine providing the standards match otherwise reliability suffers. Something like an open fire or woodburner will keep you alive even when the gas and electric fails but now most modern systems need electricity so leave you in the cold. It can be a massive investment for small rewards but for many they see free electricity without considering the initial investment and will often tie you to living there for longer terms rather than selling to move.
I wondered if it would add value to the house, but unless it was in good order and you could show bills and prove the benefits, it might have the opposite effect.
That COP just makes electric heat pump near even with a gas boiler.
There's no extra saving to pay off the massive capital cost of the heat pump and upgrades to make low temperature heating viable in an old house.
If your COP is better than around 3.5 the heat pump should be cheaper to run. We got an ASHP installed in October and have managed a COP of 4.1 in a partly insulated old farmhouse. Then there are various cheaper electricity tariffs where you can save a lot more on top. Also add in some spare PV production to run it especially in the shoulder months. No option for natural gas here anyway so it was a no brainer for us
As to adding value, it very much depends : panels added sympathetically to a modern house may put off some but may be an attractive proposition to others. Panels on an old house, especially if they detract from kerb appeal, seldom add value - generally the opposite.
With our previous house, a 1950's, they really had to be on the front of our house, in a line just below the ridge. I think they were about neutral for many when it came to selling. With the house we have now, a period house, c. 1970's, with a nice frontage and a slate roof, they are stuffed away on our garage/workshop block quite a few metres from the house and facing away from the road, thankfully. This does compromise power generation somewhat but it still retains main house kerb appeal.
Interesting - which supplier did you use for the installation? (feel free to PM). If we go down that road I would want to find somebody who knows what they are doing.
Does this mean that if I have solar panels it would be practical to use the electricity from them even if I am disconnected from the grid? How practical, maybe just intermittent, via batteries etc?
I'm interested in the "resilience".
To use solar or batteries or any other self-generating electricity supply, if you're truly disconnected from the grid, is certainly possible. If you're actually still connected to the grid, which has just gone down (supply failed due to a fault "out there" somewhere) you need an arrangement that prevents you exporting to the grid, as otherwise some electrician up a pole or in a sub-station might be fried by Jacob e-juice, as that electrician is joining up the wires again.
Such protection-for-the-grid generally comes in the form of a UPS (Uninterruptable Power Supply) box that does actually disconnect you from the grid before allowing your electrical devices to use your electrical generator and/or store. It stops you exporting any electricity to the grid when its "down" but allows your house to continue using electricity from your solar/battery.
Some systems of solar/battery come with this built-in and some require an additional "box" to perform the functions.
Whether solar/batteries and the like are "practical" depends on how much you use electricity and for what. For me, its very practical as everything is run with electricity, even the car. No electricity means no light, cooking, washing machine, heat, hot water, cold water (the "well" needs an electrical pump to extract from way down there) sewage (a pump takes it from a collection tank up 10 metres to the mains pipe) and no workshop machines. There is a wood burner but its only been lit 4 times in 6 years - to demo it rather than because it was needed for heat. I don't want to gas meself, do I? :)
For those with just a need for light, cooking, washing machine but no big consumers like heating and hot water, solar and a battery can still be cost effective. It allows you to store and later use not just solar electricity but cheap overnight electricity. For example, I pay just over 6 pence per kilowatt hour for night time electricity, loaded into a house battery, car and even running the washing machine on a timer during the 7 hour cheap period - but only through winter as most of the year the solar (used when generated and also stored in the batteries for later) is sufficient for everything. The daytime rate is 24p per kilowatt hour - 4X the night rate. But I never have to use daytime electricity.
In every individual case, you need to make a cost/benefit analysis. The benefits can be just the monetary saving but there are several others that are not cash-based: being greener; being more protected from the increasing number of grid outages; not having to use polluting and health-damaging stuff like woodburning and gas; having a degree of protection from large supplier fuel price hikes. You can also run an e-car for little or no fuel cost.
It all takes a capital outlay. But it seems better stuff to buy than a foreign holiday or spending hundreds a time to go and see some slebs twanging three chords on their guitars.
And, in the long run, you will get your money back in just about every case. If you die before you do, why care? You can't anyway, as there'll be no "you" to do so.
If you’re on Facebook there’s quite an active diy solar group that can probably give some good advice as to what to do.
Thanks @Nail
I have narrowed it down to one optimiser/panel by shielding each panel in turn using a large sheet of cardboard until I found the one that made no difference.
Of course this doesn’t identify whether it is the panel or optimiser that has failed so I need to get up on the roof and do some measurements and/or swap optimiser over with one from a working panel and see whether the fault moves.
I could reach from the top of a ladder to shield the panels but I need to get onto the roof and behind the top edge of the panels to access the optimisers.
I now wish I had not spent £9.5K on my system
Last 3 months payback have been , £6 / £6.40 / and £7 credited
We have so much cloud now due to temp change in the oceans that causes evaporation = Clouds and rain .
For me a complete £9.5K down the drain.
Not entirely down the drain as you'll be benefitting for years to come. But i agree there isn't enough cash incentive vs outlay. What size array did you go for?
We are considering having a solar & battery setup but unsure of what a realistic payback period is. If it takes (say) 10 years to break even and the kit has a lifespan of 10 years or so is it not the case that one would never be in credit due to the cost of replacing everything?
Also, I heard that with a full solar & battery system, standing charges by energy company to whom electricity is exported to, no longer apply. Is this true?
I'm still offered the same deals including standing charges and unit rate so it's not true in my case.
The 10 year life cycle isn't strictly true either, you generally have a 10 minimum life cycle with the guaranteed effectiveness of the panels. I think mine is a 0.25% loss per year in effectiveness so I have a guarantee of 97.5% effectiveness by the end of the 10 years. What those guarantees will be worth will of course be debatable.
Most solar installations are ‘grid tied’ which means they are connected in parallel with the main electrical supply.
To prevent them back feeding into the grid during a power cut, it is a requirement they shutdown when there is no mains power detected.
There are some inverters that will produce power in the absence of an incoming mains supply but these have to be isolated from the grid in order to do so.
Obviously they are very good for some but not for others. We are in the former despite our roof being east/west and in the worst possible direction. We have 16 panels, an inverter and 9kW battery and cost us just shy of £14k about 2 years ago. We also were buying an EV (due to change cars anyway) and had a home charger fitted at the same time at a cost of £1200 with electric upgrade. Our combined energy DD was about to go up to £265pm!! So after 2 years of learning, we have saved about £140pm on diesel and our DD is now £70pm. On top of that, last year we got back about £600 from SEG payments. Return of investment is very difficult to work out as we need to include the EV but very roughly we reckon it’ll be about 5.5 - 6 years at the current prices. From our experience, a large battery is essential. In the summer, no issues; your battery will pretty much be 100% charged and you’ll be exporting to the grid and use very little gas for heating. Winter is very different, heating is on a lot more, you create very little solar and you will constantly be using all the battery (keep 10% in reserve). Charge it up to 100% overnight using cheap electricity and try and also use your white goods overnight too.
Sorry for being long-winded but that’s our experience. Getting on the Octopus EV rate was essential and you must have an EV charger and smart meter for that (note standing charges are higher for this rate). Is it worth it? For us 100% yes
An east west split is actually quite good in performance- where I lived previously had an east/west split (3kw in each direction) plus a nearby neighbour had an identical system installed literally two days later (by the same crew even) but all facing north... fitted in 2016...
That's the east PV array and the north thermal panel, the west PV array is on the other side, and an overhead shot from google earth...
In practice- although his had a higher midday peak, ours started earlier, and finished later, with a lower, but longer midday peak- and the end result was both gave exactly the same total daily generated kWh per day....
Except in overcast conditions...
There we usually had a LOT more generated per day in comparison to his all north facers... (by several kWh a day- usually 5-7kWh a day more than his 'ideal' facing panels!!!)
We paid $4000Au at the time of install, and it was fully paid off by the time I moved out in 2020...
Of course my 'new' place is solar powered- in fact there's no mains connection at all- I spent under $18k Au all up for a 18kw array (72 250w panels) 12kw inverter, 20kWh battery bank, that paid itself off from day one (I could have doubled the systems size, and it still would have been cheaper than getting a new 8kw grid connection onto the property ($42k Au)- and no bills or blackouts lol
A lot depends on how techsavy you are- a gridtie (with its attendant high costs and low feedback rates) has pretty much become a nightmare, many home owners here have gone batterybacked gridtie systems instead, where your panels recharge the batterybank, and only export after they are full, and the houses uses are covered basically by the battery bank, with only occasional 'dips' onto the grid ie off-grid, but using the mains grid as an 'emergency generator'...
If the panels are from one of the reputable Tier one suppliers, then it doesn't matter who the installer is, the panels themselves will be covered by the manufacturers warranty...
Most panels these days have a 25 or 30 year output guarantee, usually 85% to 90% plus after that time period, and yes they do last that long (and far longer) in just my family we have a system installed in 1997 (mums), 1999 (my uncles), 2008, expanded in 2017 (lil sisters) and my first offgrid system (still in use at an ex neighbours (1984)- all still right in line with the expected results...
Even the old ones I started using in the 1980's at my first offgrid house- now at my ex neighbours down south- are still well over 70% of their 'as new' output- but considering that the power consumption of the loads has dropped markedly over the years since they were first bought, they can actually still handle the same 'loads' even though their output has dropped by about 25%- lighting at the time was incandescent or ballasted fluro, now LEDs do the same job with the same brightness at 1/10th the power consumption, the TV was a 18" CRT TV that chewed a couple of hundred watts, these days a LED LCD uses about 50w and is huge in comparison lol
Inverters usually have a 8-10 year warantee as well, but actual failures are pretty rare- in practice I have only heard of three failures in family and friends- two from the same storm (lightning strike on the powerlines took out everybody's inverters in the street- as well as many other devices) and the third- well- that was from the floods in Brisbane... inverters tend to not work after being underwater for several days... as in the inverter was mounted on the house wall- and the flood waters were over the gutters of the house....
But apart from that, they do tend to be quite reliable for the better known brands...
Trina are one of the largest panel manufacturers in the world (and been in business over quarter of a century...)
Panasonic is equally well known...
Use a WHICH recommended supplier.
Are there any ?
"Which", being what they are, will only be able to review a modest number of larger businesses.
Those guys rely heavily on subcontracting the work out to local installers.
So in the end, you're back to personal recommendations or learning about solar yourself so you can ask good questions and judge the local outfits for yourself.
Are you sure about that? 🙂
“Even the most ‘eco-friendly’ wood burning stoves emit high levels of fine particulate matter (PM2.5). This report commissioned by DEFRA reveals that on an equivalent hourly operational basis, an Ecodesign stove is likely to emit six times the mass of PM2.5 than a diesel Euro 6 HGV (see figure 2 on page 18).”
https://www.mumsforlungs.org/our-campaigns/wood-burning
As for moving house, most of what I’ve read suggests that solar panels increase the value of a property.
We have been using open fires for milenia, yes they were not the cleanest but back then our population was many millions less than it is now. It might even be that with the current levels of population we are actually doing more harm to the enviroment than the opens fires because of peoples lifestyles and our materialistic attitudes.
BILLIONS- not millions...
And thats why we desperately need to 'clean up our act'- when the entire worlds population would today fit in a single small city, we could afford to be polluting- there simply weren't enough of us to make a difference...
Now with the human population exploding in numbers, if we were still polluting on those levels the air would literally be unbreathable...
https://www.worldometers.info/world-population/world-population-by-year/
We need to emit far less per person- or have less people...
And for some reason people tend to frown on 'culling humans' like an exploding mouse population...
:unsure:
(and even in our remote areas like where I live- fireplaces have become a rarity- even on my 40 acres, I can tell when people two doors down light their fireplace...)
