Socket wrench?
Niall Church
22 Apr 2023
Anyone know where I'd get one these?,I know it oldish,has to be like this,though!
    852.1 KB
    873.3 KB
This only 4" in length altogether! Not a breakers bar,or a choclate bar!
It is still called a breaker bar even though it is for 1/4" drive sockets. I have one in 1/4", 3/8" and 1/2" along with the T wrenches, ratchets and speed wrenches. Each one having a place in the tool box. The breaker bar being able to apply more force than a ratchet to save the teeth in the ratchet mechanism.
Because they are used to initially loosen a fastener, you don't want to subject your ratchet to the abuse a breaker bar can get.
It'5" in length and a spring loaded ball bearing the the square piece so the bit doesn't fall off! It wouldn't be uaed for very heavy work!
It will be used in place of a 5" long ratchet to break the nut/bolt free. Once free you switch over to the ratchet. Small fasteners that have over time corroded a bit take more force to release than was used to tighten them in the first place. If you can only get your hand in the working area (like in a light aircraft wing) then you use the little breaker bar to loosen the fastener a bit before switching to the ratchet. If you don't you can wear out a ratchet prematurely or break the ratchet pawls. Not something we wanted to do when the ratchets cost so much especially when you are in a bush camp and might not see a tool store for weeks. Pretty much every handle/tool that hold sockets have a ball detent so they don't fall off while you are working. The "heavy work" is relative to the size of the tools.
Ok,well,this was used to loosen a nut and it's broken.
All the ones I have had, have had that spring loaded detent to retain the socket, the power drive versions normally use a pin. I will look tommorow as I think I might have a brand new 3/8 drive Britool one .
...something entirely different to the OP's picture and stated requirements.
The correct item is known as a 'breaker bar'.
Lol. You don't listen to feedback much, do you?
You've undoubtedly a lot to offer in terms of experience and knowledge.
However, I'm genuinely curious - what is your pathological need to be as curmudgeonly as possible? Where has it come from? Are you even aware of it?
I'm guessing white, male, 60s, single, single/two employments, narrow field where specific knowledge valued, "tidy" (mild OCD), "precise" (mildly ASD), rather baffled by the disorderly rough-and-tumble of the world.
Am I close?
BTW, I tick a lot of those boxes too - but I'm adequately aware of it!
