Niall Church
- Joined
- 22 Apr 2023
- Messages
- 228
- Reaction score
- 11
If you google socket universal joint you'll see...
This only 4" in length altogether! Not a breakers bar,or a choclate bar!...something entirely different to the OP's picture and stated requirements.
The correct item is known as a 'breaker bar'.
I'm actually looking for the whole thing in the photo!If you google socket universal joint you'll see a selection, or socket adaptor if you want to change the drive size
https://uk.rs-online.com/web/p/sock...H5ipL2SMCskydpgVDKMaAqazEALw_wcB&gclsrc=aw.ds
It is still called a breaker bar even though it is for 1/4" drive sockets. I have one in 1/4", 3/8" and 1/2" along with the T wrenches, ratchets and speed wrenches. Each one having a place in the tool box. The breaker bar being able to apply more force than a ratchet to save the teeth in the ratchet mechanism.This only 4" in length altogether! Not a breakers bar,or a choclate bar!
Because they are used to initially loosen a fastener, you don't want to subject your ratchet to the abuse a breaker bar can get.It is still called a breaker bar
It'5" in length and a spring loaded ball bearing the the square piece so the bit doesn't fall off! It wouldn't be uaed for very heavy work!Because they are used to initially loosen a fastener, you don't want to subject your ratchet to the abuse a breaker bar can get.
It will be used in place of a 5" long ratchet to break the nut/bolt free. Once free you switch over to the ratchet. Small fasteners that have over time corroded a bit take more force to release than was used to tighten them in the first place. If you can only get your hand in the working area (like in a light aircraft wing) then you use the little breaker bar to loosen the fastener a bit before switching to the ratchet. If you don't you can wear out a ratchet prematurely or break the ratchet pawls. Not something we wanted to do when the ratchets cost so much especially when you are in a bush camp and might not see a tool store for weeks. Pretty much every handle/tool that hold sockets have a ball detent so they don't fall off while you are working. The "heavy work" is relative to the size of the tools.It'5" in length and a spring loaded ball bearing the the square piece so the bit doesn't fall off! It wouldn't be uaed for very heavy work!
Ok,well,this was used to loosen a nut and it's broken.It will be used in place of a 5" long ratchet to break the nut/bolt free. Once free you switch over to the ratchet. Small fasteners that have over time corroded a bit take more force to release than was used to tighten them in the first place. If you can only get your hand in the working area (like in a light aircraft wing) then you use the little breaker bar to loosen the fastener a bit before switching to the ratchet. If you don't you can wear out a ratchet prematurely or break the ratchet pawls. Not something we wanted to do when the ratchets cost so much especially when you are in a bush camp and might not see a tool store for weeks. Pretty much every handle/tool that hold sockets have a ball detent so they don't fall off while you are working. The "heavy work" is relative to the size of the tools.
All the ones I have had, have had that spring loaded detent to retain the socket, the power drive versions normally use a pin. I will look tommorow as I think I might have a brand new 3/8 drive Britool one .It'5" in length and a spring loaded ball bearing the the square piece so the bit doesn't fall off!
