adrspach":2yrlh6g0 said:A lot of people use strops with pastes which then in effect levels all the differences between hones.
Very true.
bridger":3ea4qrs9 said:once long ago I had a slate/sandstone two sided stone from china. it was too slow to be useful to me.
a couple of years ago I bought some slate tiles at the local builder's supply and cut them up to hone sizes and flattened them. they were spectacularly unsatisfactory as sharpening stones. so soft that the surface quickly became rutted, so slow cutting that I'd die of boredom before getting to an edge and the effective grit was much lower than the look or feel of the stone would indicate (it scratched the heck out of the tool).
Cheshirechappie":1o3ff0jn said:The slate doesn't really cut much at all, but it does seem to burnish or polish edges very well.
Cheshirechappie":1o3ff0jn said:Just in passing, I'm not sure that the 'proper' slate hones are technically slate at all - mine has no discernable cleavage planes. I gather they are made from a material properly called 'hornfels' which is often found in the same areas as slate beds, but is geologically slightly different. In slate, the mineral grains are aligned by pressure to give the characteristic easy cleaving into thin sheets, whereas in hornfels the mineral grains are not so aligned.
