This is fantastic thank youIf tasked with this window I would do the following.
It appears my glaziers don't supply this type of glass - hence I wasn't aware of it.
Yes low sightline is what I've been after - I can then replicate just without the sliding sashes. I'm thinking of it as a piece of art rather than a window which I appreciate is a bit odd but then it's the clients choice.
Making the curved glazing bars is my next issue - would you have three panes or 'stick on' for the top section?
I'm imagining a jig for an arc cut across the router table to profile (and haven't got my head around the tenons yet!)
Thank you!
For the sake of a few minutes, I would strongly recommend checking with the LA, all it usually takes is a look on their planning web site, put the post code in to check, it could be problematic if, after it's made and fitted you find out it is, or someone else does.Is it not in a conservation area? It should be!
What is your experience with the longevity of double glazing when installed wet with Hodgesons Heritage Putty? Do you still use rubber setting blocks and locating blocks? I've read over the standards for modern dgu and they suggest dry install.If tasked with this window I would do the following.
Copy it`s design and mouldings and make it traditionally, adjusting slightly for double glazing.
I would use individual dgu`s with 6.5mm sightlines something like a 4/8/4 with krypton fill to give a decent` U value.
You may have to increase the glazing bar width to fit the units but you can go as slim as 20mm at a push, I normally do 22 mm if I can. You won`t notice much difference because the painter has probably put 5mm on the glass by now anyway so the new one will look the same.
Glaze using hodgesons heritage putty ( H1 system).
Draughtproofing on parting and staff beads and meeting rail.
Stick on bars look odd, and conservation officers generally don`t like them in my experience.
Its quite like the ones I am doing at the moment except fancier, these ones don`t have double glazing but accoustic laminate. New bottom sashes, new cills, repaired upper sashes, all new glass, lime pointing.
They are wierd because only the top ones open using a rope and pulley.
View attachment 196306View attachment 196305
View attachment 196304View attachment 196302
Timber Windows: Avoiding Common Failures – Water Ingress Around Glazing
"Fully bedding glazing units on sealant should not be accepted as a method to install IGUs as it leads to failures."
