Gate Design
as others have said the tongue and groove design will lead to premature failure
I would also mention that if you are making from kiln dried oak the t&g boards will swell considerably when the gates go outside
if it was me I would condition the wood outside before machining it to finished section
Ive made plenty of outside gates and know the problems -professional gate makers leave their timber stock outside under cover.
10 -12% MC of kiln dried stock is far to low for external use where it needs to be 16%
the tongue and groove boards cant be used as a structural element, each board needs a gap of probably 3mm between the next one and so they can only be fixed top and bottom
you have around 20 t and g boards, each one might swell up by 2mm so you could be looking at total expansion of 40mm over the span of the boards -if you dont give enough gap the boards will force the gate joints apart
Something like this would ticks the boxes.. where the centre engages with the boards. It's just alot of wood to remove and a bit of a pain of a shape to router. (I've got close to 6m to cut)
That is what I was trying to describe. If you make the slope without the little flat then the water won't stay in there once the rain stops. The ones sitting on top being cut flat across the bottom.
I'd stop thinking of the panelled area as a web, gates don't tend to use that unless they are plywood or steel. The gate needs to be structurally robust without the panelling ime.
There is a narrow lane your pulling off so your turning 90 degrees as well as pulling in. I've also added a pedestrian gate one side.
It could be made less, but it's surprising how often I want to reverse a luton van in or have hired a skip.
I live on a narrow country lane, drive a long wheelbase panel van and sometimes have a 5m long Ifor Williams flat bed trailer to contend with as well, never had a much of a problem reversing them in through my gate entrance to be honest.
The software is solidworks premium, It's just modelled as one big lump. I could set the model up with all the joints, pins, friction, add the oak properties so it takes into account grain direction..etc etc etc
Then I could model the airflow over the gate.. work out when it will resonate.. I could be optomising it for the next 3 months, maybe shave 40kg off the weight...
I always thought that's what engineers did!
If my oak gate lasts 36 years I will be amazed, I'll be happy with 10
If I make anything for a client they expect a lot longer life than 10 years, and so would I.
Any way best of luck with your project, be good to see it when finished.
Don't be to optimistic. I'm replacing some 8 inch oak post after 15 years. I snapped both with my bare hands! There being replaced wit 5 inch galv steel. The gates weren't great either but salvageable just.
    12.9 MB
I already have the wood so the gate posts are going to have to be extened with concrete and steel
happy to go down a meter
View attachment 197605View attachment 197607
This is very boring.. I'm not keeping in sheep, I also want to reduce the wind blowing down the drive.
I also can't cut curved timbers as I don't have a big band saw.. I cut My first ball with a router and it was painful enough.
The first design had a curved top, but i decided it was too hard to cut.
I watched a video on similar and the general consensus was that the rot proofing was a bit of a wate of time.
I'm hoping the post savers will reduce most of the rot in the uprights.
Happy to varnish it every couple of years.
The curve isn't actually necessary; it's just a stylistic thing. Just extend the hanging stile upward until you get a sufficient angle on the gravity brace.
Depends how the gate is designed..
What about this..
The frame stays similar but has two extra uprights. (Blind moortice and tennon joint)
I also Router some slots for the panneling
Bottom beam looks like this,
The timber panels slot into this gap
Finally a diagnal beam is added to the back
It's far better to do away with any chance of rain accumulating in joints and grooves, face boarding is better on the face of bottom rails
The bracing you have now introduced is a major improvement to help keep these big gates in order.
Regarding closing systems it's essential to have it all worked out before beforehand.
Things like opening angles, power supply and hanging ironmongery can easily throw a spanner in the works.
Cheers, Andy
Cheers, Andy
I can also put a chamfer with the plane along the back edge of the bottom beam so the water runs off.
There replacing some very rotten wooden gates.. (One is completely missing), So I know where they open to..
Electric openers will be something like this connected to the middle bar
I'm not too worried about the hinges, My tig welding is pretty neat and the top hinge is going to need to be heavily modified but nothing that can't easily be done.
What about this..
View attachment 197741View attachment 197742
View attachment 197745View attachment 197746
Braces start to loose their ability to stop sag if placed below 45 degrees. You can put them below 45 degrees but they won't be as effective.
I would think the above design is better for rigidity than your previous designs. Don't notch the intermidiate uprights Just mortice and tenon them into the framework and use draw bore method.
The pins as you call them are best made from chopping oak with an axe and planing them to shape, they will grip better and be stronger than if off the shelf. They are better if they are not completly round as they grip better, plane very slight flats that form a round peg.
If you don't notch them in, the planks end up longer than the intermidiate uprights on the front face ends up looking strange..
It's also alot easier to router a long groove than try and leave islands for the uprights.. like above
There are alot of gates that would disagree., at 32 degrees vs 45 degrees I drop 17%
I wonder what brace shape is the strongest... Visually I think I prefer it like this..
Does anyone know what's going on here. With this joint? Is it a third bit of wood (sandwiched )
If you do sit the boarding on a rebate in the bottom rail it might be worth putting a bit of a bevel on the rebate and cutting the bottom of the boards on an angle to match.
I think when @meccarroll said don't notch the uprights in he meant make the tenon shoulders stepped/front longer than the back so you don't need notches or islands if that makes sense?
Most professional joiners would run the boards past the bottom rail. as in a framed ledge and braced door. People have been trying to tell you that but you do not seem interested.
I never knew a gate could disagree LoL. The above gate is a design that relies on multiple connections for support, it is lightweight unlike your gate.
You can put braces below 45 degrees but they start to loose their ability to withstand the drop.
You can make a gate and just put mortice and tenons in and if it is glued could and should be fine. If you are fitting the gate together dry then if the braces are at 45 degrees they stand a lot better chance of withstanding the drop. It is entirly up to you how you build your gates. For your design I would try to get the braces as near to 45 as is practical. Your spacing etc should work ok as is I would think.
What about this..
The strut braces are individually more effective. But you now need three of them. Which means three bottom end joints subject to rot from trapped water . . . .
