nosuchhounds
Im looking to add a shoulder plane to my setup but just wondering which size would be best suited for all purpose work?
78 good for shoulders too if sharp enough. A lot cheaper than a "shoulder" plane, and other uses too.Medium, can do most things. For delicate small stuff a small if that’s what you mainly do.
He’s asking for a shoulder plane, which is used to square off tenons and alike. He’s not asking for a plane to cut rebates.
I've got Record 073 and 042 I assume they are called a shoulder planes because they are for trimming shoulders. That's what I use them for anyway! Basically a finishing cut after a chisel etcEveryone is different and there are many ways of doing things. My use of and understanding of the principle use of a shoulder plane is that its not to cut shoulders. A tenon done my hand has the shoulders typically cut with a saw and the waste removed either by saw or chisel. Typically pairing chisels are used to adjust the fit of the tenon checks and the shoulder plane is used to remove minute whiskers off the tenon cheeks to adjust the fit so that there is no gap. The plane (say a Clifton which is a typical tradition design ) has a very tight mouth and can only take very small amounts off.
I have the record 708 and cannot image using it to finesse a tenon on anything other than carpentry type work. I make the distinction between that and Joinery work, or cabinetry.
Well yes thats the way to do it! But they often seem to need a little trim!For furniture and joinery I'm a devotee of accurate marking out and cutting to the line with a 14pt backsaw ... and that's it.
I have a 78 already so will try cleaning up tenons with that I just felt that a shoulder plane would help finnesse them
Not really. It's more of a novelty bench plane but in fact turns out to be very useful even on site, which is why a lot of them turn up obviously very well used but with the add-ons missing........
It's a site plane
and useful and cheap.with a relatively coarse finish - referenced a lot in the last 50 years more or less just because it was available and still made.
Shoulder planes do a lot more than just tidy up tennon shoulders/cheeks. While a 78 will also do a lot of things it is nowhere near as sophisticated and delicate to use. I have a couple of old infill planes a record 73 and a medium veritas. The old planes work very well once you know how to adjust with just a wedge and small hammer. I find the 073 a bit large and the veritas is my go to. i know not everybody likes the little knobs/handles but I do.
One comment is that unless you can get a really good sharp edge you will not get a true feel as to how they perform
