Whizzo
New member
Hi.
Im using vandyke crystals to stain some pine work tops prior to waxing. I find that this water base stain lifts the grain and even if I rub it down with 320 after it dry's the finish is not a smooth as I would like.
I am thinking of using shellac sanding sealer prior to staining. Can anyone tell me if this will make a better finish and will the stain still soak in enough, or should it be applied after staining?
Thanks.
Thanks.
