johnnyb
I'm not getting involved only to ask about Jacobs tables. I have a vague memory of you setting up to sell them. Any other pics. There nicely styled and thought out.
It's not a term I've ever heard before this thread, but it's the trick of planing/jointing the edges of two boards in one operation by clamping the boards face-to-face in the vice. When you flip them together to edge-joint, if you planed the edges slightly out of square the angles should cancel out.
It when you place the two faces of a board to be edge jointed and plane both at the same time. The theory being that any tilt left or right is mirrored on the other part resulting in a perfectly square and gapless joint. I use it with smaller boards and it is a quick approach because it’s half the planing. You can still spring the joint using this method. For longer boards though I don’t use it as this corrects for left to right not end to end. In fact it doubles the error end to end.Can one of the more informed, explain what match plaining is
It what you do when you get arthritisWhat's a rub joint?
Joking!
I sold a few. A late venture before I got into a big project converting a chapel.I'm not getting involved only to ask about Jacobs tables. I have a vague memory of you setting up to sell them. Any other pics. There nicely styled and thought out.
What's a rub joint?
Joking!
It's how the original was. Small advantage in that you can attach a knob more solidly with a longer glued-in joint pin.Those drawer fronts are unusual Jacob, at first I wondered why you had used lap Dovetails when you were putting a false front on top, the I realised how you had use a thick solid piece, I shall file that away for future use.
Jacob you keep trying to denigrate this method of edge jointing, I think because you had never heard of it and perhaps you see as a bit of dent in your knowledge, maybe?If you dip say 1mm along the length of doubled up boards being "match"planed, when you turn them to meet the gap will be 2mm. If the dip is across the width then they will cancel out, in theory!
Hadn't thought of that - "match" planing can magnify errors. Probably why nobody does it much.
No it was because I didn't know it had a name and was immediately jeered at and berated by yourself and mudman.Jacob you keep trying to denigrate this method of edge jointing, I think because you had never heard of it and perhaps you see as a bit of dent in your knowledge, maybe?
Yes speed. Probably used most often to scribe a board to an uneven surface - pencil off the line with the board butted up then axe back to the line, undercutting slightly, tidy up with a block plane mostly across the edge, not along it.That sounds like it was a fascinating experience Jacob, real back to basics stuff, my parents early Victorian Chippendale chairs were hand axed on the inside of the seat frames, it’s a quick way to remove timber I suppose.
Well yes, I'm not into discipline either, self or otherwise, but at the time it felt as though it was doing me good!That’s a blast from the past, Tops course. I looked at doing the carpenters course, but I am tooooooo much of a free sprite to follow strict/rigid teaching
Still is in mineUsed to be standard item of kit.
I didn`t jeer or berate, I just pointed out a use for a straight blade.No it was because I didn't know it had a name and was immediately jeered at and berated by yourself and mudman.
I expect I must have had a go at some point - as I said it seems to be one of those many "good ideas" which get kicked around a lot but unfortunately never quite go away!
