Lons
Yep you got it Phil, feel free to substitute any other words you feel more appropriate. I just feel sorry for the poor old fella.For what exactly is "unique" a euphemism?
"Fella" might just be a euphemism as well
That's brave of you - I'm surprised you would admit this as a member of the correct sharpening brotherhood!I've ground chisels and plane irons on a disc for decades, you just vary the pressure a little from side to side to compensate.
Several points immediately come to mind.It's perfectly easy to do spindle gouges and skews freehand on an oil stone.
With a bit of thought the steeper angled gouges aren't difficult either.
Saves a fortune on kit, quick and easy (a little and often), prolongs chisel life.
It's perfectly good for flat bladed tools. It's not the best for gouges.That's brave of you - I'm surprised you would admit this as a member of the correct sharpening brotherhood!
Or is it allowed in the rule book somewhere?
Not at all, once you get into it. Has to be forceful and fast.Several points immediately come to mind.
If your sharpening a flat bevel you have to remove metal from the whole surface - really impractical & slow with an oil stone.
Unless you use a coarse stone. And has to be forceful and fast!Don't try re-profiling your tools with this method, it will probably take a year.
Yes. But it's quite nice to be in control without all the pricy modern tackle.A hollow grind, as from a grinder can quickly be sharpened with the latest in modern technology, a diamond file/card.
That was my route into sharpening. Start with a wheel, add a cheap wolverine type jig for repeatability, then shell out for CBN once you can justify the investmen.I would also add that many who use the wolverine system, eventually get CBN wheels.
Yes, because it’s about turning tools not real sharpening@ OP and here endeth the first lesson in why we don't mention the 'S' Word ..... although to be fair this is quite a civil and restrained thread
Perhaps good turners are lousy sharpeners?I was merely making a point. Your advice to a learner is contrary to what dozens (probably thousands) of more experienced turners would give. Just because you're happy with it doesn't mean it's the best advice. I could probably get a fingernail grind on a spindle gouge using a concrete coping stone if my life depended on it, but it wouldn't mean it was the best way of doing it, good turners use jigs for a reason.
Or coarser oil stones if freehand etcGood turners don't seek or need razor sharp tools. As explained elsewhere a turning gouge will go through more metres of wood in a couple of minutes than a hand tool would in a morning - it would cease to be razor sharp in seconds. They use jigs for speed and economy.
Cheaper and utterly superior is freehand with 2 or 3 oilstones. Less than £50 will see you kitted out for life.Sorry for bringing this back up again, but I need a sharpening set up and have a limited budget. I was thinking of buying one of these with the woodturners sharpening package:
https://www.recordpower.co.uk/product/wg200-8-wet-stone-sharpening-system-package-dealhttps://www.recordpower.co.uk/category/sharpening-jigsI like the fact that it is adjustable speed, and was hoping to eventually buy a CBN wheel to replace the one included.
My question is does anyone see any problems with it? I can't afford the Tormek system yet (maybe sometime in the future!) so that is out of the question, but if there are any other systems around this price that are equivalent or better then I'm all ears.
Thanks in advance
Chris
Is it for woodturning tools you want it for? If so I'd probably not go for a Tormek like device as you'll probably find it too slow. Have a look for a decent bench grinder. If you're happy to freehand it then that should suit you but for more consistent grinds you'll probably want to either make one or invest in a suitable jig.Sorry for bringing this back up again, but I need a sharpening set up and have a limited budget. I was thinking of buying one of these with the woodturners sharpening package:
Thanks in advance
Chris
For woodturning a sanding disc on the outboard end is good. And/or an mdf disc plus smears of autosol for instant polish.Is it for woodturning tools you want it for? If so I'd probably not go for a Tormek like device as you'll probably find it too slow. Have a look for a decent bench grinder. If you're happy to freehand it then that should suit you but for more consistent grinds you'll probably want to either make one or invest in a suitable jig.
Yes agreed. An 8” bench grinder would be a better bet in my view. You can buy or make the jigs for it.Is it for woodturning tools you want it for? If so I'd probably not go for a Tormek like device as you'll probably find it too slow. Have a look for a decent bench grinder. If you're happy to freehand it then that should suit you but for more consistent grinds you'll probably want to either make one or invest in a suitable jig.
