Jacob
What goes around comes around.
er - so what?I was in a club with very experienced first class amateurs, semi pro and pro turners - not one of them ever, ever used an oilstone.
For what exactly is "unique" a euphemism?I've been turning wood for 60 years and in all that time have never seen a turner use oilstones, the pros certainly don't either if you watch any of the demonstrations but then the person offering that advice is rather unique.![]()
I was merely making a point. Your advice to a learner is contrary to what dozens (probably thousands) of more experienced turners would give. Just because you're happy with it doesn't mean it's the best advice. I could probably get a fingernail grind on a spindle gouge using a concrete coping stone if my life depended on it, but it wouldn't mean it was the best way of doing it, good turners use jigs for a reason.er - so what?
Don't worry about it Phil, suit yourself how you sharpen.I was merely making a point.
Exactly. That's what I said. And some of them may still be basic!Yes, it's useful to get back to basics - that's when you learn there are better ways.
Unique is not an adjective I'd useI did exactly the same and managed to get a good second hand one though I already had a grinder and a Tormek T7, kept the grinder for metal work and sold the Tormek as I found the Pro-edge far quicker for frequent touch up of lathe chisels.
Quite right too. I doubt I'm the only person in the universe who finds it easy to sharpen a gouge or a skew chisel on an oil stone.Unique is not an adjective I'd use
Not "ill advised" - it has been the method for millennia and is described in all the old books, Percy Blandford etc...... But using oil stones for turning tools is just ill-advised for many reasons.
You do what you want, it makes no difference to me.Not "ill advised" - it has been the method for millennia and is described in all the old books, Percy Blandford etc.
It's just an alternative worth investigating, especially if you haven't already lashed out on a lot of kit.
I had a Pro edge for a while but thought it wasn't good value when I discovered how effective are discs on the outboard end of headstock. (see above) so I sold it on.
I'll carry on doing it my way, sorry about that, I hope too many people aren't offended!![]()
Me neither but I was in a more mellow mood than usual and the forum software substitutes swear words anyway.Unique is not an adjective I'd use
Like a lot of these things you just do it without thinking too much. A few mistakes at first of course. It ain't rocket science.Using a disc sander - how is the blade held - radially or tangentially.
Held radially for narrow tools may be a useful alternative sharpening method. For plane blades I would be concerned that the difference in abrasive speed on inner and outer edge would make it difficult to achieve a constant sharpness and alignment along the whole edge.
Held tangentially ensuring that equal pressure is applied across the whole of a wide blade would be difficult - a small slip could could rip the abrasive.
