Scrolling vinyl records
I've been in the garage for a couple of hours and unearthed the records while I was there, so out of interest I had a go with the #5 reverse blade I already had in. Speed was about 1200, and it cut perfectly with no welding and nothing to clean off the underside. It tended to flex and bounce a bit, but holding it down with a small piece of ply cured that.
I also had a play. Covered the front & back (a & b?) sides of the record with masking tape, pritt-sticked the pattern to it and cut around the outside of my pattern.
Used the blade that was already in it, either a #5 or #6 and the slowest speed my saw would go.
No welding, and any fuzzies on the back just flick away with an old toothbrush.
Well, it's done.
There were a few fuzzies that won't brush away, but I doubt it'll ever get to that stage of finishedness (?)
I just wanted to see how it cut and if I could.
... at least it's an improvement on the original 'HITS OF HAWAII' :D
NazNomad":2w8dppwy said:
Well, it's done.
That's worked great Naz pity its not Bat out of Hell :lol:
Brian
I'm obviously not as trendy as you lot. I've got a stack of vinyl and some old sunglass lenses. :)
cracking drawing.
