That would be ok providing you have not upset your AI and it is seeking revenge !Video camera with AI analysis
I wonder where, air bags, abs, seat belts, traction control and the plethora of safety devices built into cars nowadays fits into the discussion. Surely they're not required when an experienced and well trained driver is controlling a ton and a half of steel at 100 kph in heavy rain with the kids in the back seat. Just a thought.![]()
Not Jezzer with that one. It was a chap called Gordon TullockJeremy Clarkson was also famous for saying that cars should have a metal spike in the steering wheel - you would drive more cautiously - so there is an interesting discussion around perceptions of safety and how that affects risk... would having saw stop on a table saw increase the risk you are prepared to take (what if the saw stop then failed to work?!) would having a table with an open 20" blade making a lot of noise make you more cautious?!
Have you had one fitted yourself? If not why not?What I can't understand is why there are people that seem to think that a saw stop should not be fitted.
If the saw stop was fitted on all saws then maybe not such a problem but if you have the saw stop then what effect on your own attitude to safety, knowing the saw cannot cut fingers off could make you take risk you would otherwise not take and then one day in a colleagues workshop helping out using a standard saw you forget not all saws have saw stop and before you know it you can now only count to nine !!What I can't understand is why there are people that seem to think that a saw stop should not be fitted. Their whole reasoning seems to be that people should be well-trained to a professional standard, be fully aware of what they are doing, not take risks, use guards and, to keep hands well away from the spinny sharp thing by using appropriate remote manipulators. All that is all well and good and yes, that would be ideal and the theory is then that there should be no possibility of an accident. But, safety devices such as the saw stop are there for the unforeseen events that might happen.
Clarkson must have been quoting him then as he definitely used to talk about it quite a bit!Not Jezzer with that one. It was a chap called Gordon Tullock
No I haven't. I don't own a table saw, I don't have the space but if I did, then I would be keen to have one with a saw stop.Have you had one fitted yourself? If not why not?
"Good practice" is extremely simple and can be taught in seconds i.e. "Keep your hands well away from dangerous cutters in action". That is all you need to know - hardly "well-trained to a professional standard".
It's simple stuff like "keep your hand away from a fire" which even little kids can understand.
Could add dimensions if in doubt, say 6 to 10 inches away, depending on what you are doing
Next step is how to achieve this, push sticks, power feeds, sliding tables with clamps etc
Saw stop not a good idea
1 It can't be fitted to existing machines, of which there are millions
2 They haven't been developed for spindles, planers etc
3 Being mechanical they are not fail safe
4 Expensive
5 Safe practice very easy to achieve from the start.
No, you would continue to employ all the good practices that you have been employing in your own workshop. Another very strange reason. Others might not have it so you shouldn't either. Some vintage cars don't have seatbelts, does that mean we shouldn't have mandated them in more modern cars in case people forget when they get in a vintage car?If the saw stop was fitted on all saws then maybe not such a problem but if you have the saw stop then what effect on your own attitude to safety, knowing the saw cannot cut fingers off could make you take risk you would otherwise not take and then one day in a colleagues workshop helping out using a standard saw you forget not all saws have saw stop and before you know it you can now only count to nine !!
The best saw stop would be one that when activated to save your digits also wrecks the blade which would cause expense and inconvenience so making you avoid activating saw stop and use push sticks, so then why not just work safetly in the first place and not look for excuses not to.
Why would you be against something that has the potential to prevent thousands of debilitating injuries?What raving nonsense. Somebody needs to tell them about push sticks.
Or the trade will gang together to sell us masses of expensive gadgetry
Not a hope in hell, he’s so delusional as to think that the only opinion in the world that deserves consideration is his own. That’s how it has been for years so don’t expect any change nowI hope you can respect another's wish to have a great safety device running in the background.
Because it wouldn't prevent thousands of debilitating injuries unless there were millions of saw stops installed, and even then the remainder would have to rely on normal safe practices on saws and other machinesWhy would you be against something that has the potential to prevent thousands of debilitating injuries?
I think it's very likely that it does prevent hundreds of accidents, but we'll never know until someone does a comparative study of some sort.And please don’t rant about push sticks in your answer, we all know the benefits of them and it’s common sense to use them, but that seemingly doesn’t prevent hundreds of accidents every year.
You mean I shouldn't have any opinions that you don't share? Actually a lot of people seem to think like that! I guess it makes them nervous.Not a hope in hell, he’s so delusional as to think that the only opinion in the world that deserves consideration is his own. That’s how it has been for years so don’t expect any change now![]()
Your circular arguments are mind boggling. So because other people haven't got something, then no one should? You make less and less sense as you frantically dredge up some other confirming opinion as you have no real valid arguments.Because it wouldn't prevent thousands of debilitating injuries unless there were millions of saw stops installed, and even then the remainder would have to rely on normal safe practices on saws and other machines
Have you got a saw stop yourself?Your circular arguments are mind boggling. So because other people haven't got something, then no one should? You make less and less sense as you frantically dredge up some other confirming opinion as you have no real valid arguments.
I don't think anyone has ever said you shouldn't have an opinion. what people have said is that you really need to stop constantly banging whatever drum you have nailed your colours to. Just constant repetition and facile opinions that are often wrong but you can never back down or admit there is the smallest chance you might be wrong.You mean I shouldn't have any opinions that you don't share? Actually a lot of people seem to think like that! I guess it makes them nervous.It just makes me laugh.
I've already said I haven't.Have you got a saw stop yourself?
