Jester129
I'll rephrase my question - what do you use to start these heaters please?
Good Question. I forgot to say in my previous supply.I'll rephrase my question - what do you use to start these heaters please?
There are two ways of doing this:Thanks for the replies. Based on these, I think a 12v 'leisure' battery (read caravan' battery) is the way forward, with a smart charger to keep it topped up, is the route I'll take. I hope this will work with the 8Kw heater that is now on order.
When I eventually sell my bungalow to down-size to a smaller one nearer or in the nearest town, the (soon to be) extended garage should be toasty warm so I can make stuff through the winter.
Installed the backup battery (Yuasa, sealed, rechargeable burglar alarm style) this one and automatic switch this one today. If the 12v from the mains transformer fails, the relay opens and the backup battery 12v is utilised. There is about a 30milisecond switchover delay where no power gets to the heater. When the battery then kicks in, the heater goes into its shutdown cycle. I bought the 30amp switch since the heaters draw around 12amps in startup mode and I wanted a bit of headroom. It was only a couple of quid more expensive that the 12amp version.
All does exactly what I wanted.
