It’s 2KW but doesn’t run continuously. To be honest I have not measured the cost.What is the running costs like with these.
Clive,
Clive,
First I misread it, and wondered why you sat your bare ar$e on the bandsaw tableI have an Erbauer BGP2108-5 free standing fan heater from Screwfix, should I require heat in my 'bat-cave', but this time of year I spend as little time as possible in there. I did go out there on a sunny day last week to use my bandsaw, and the table 'weren't arf cold on bare arms!!!!'![]()
energy cap is c. 27p / kwhWhat is the running costs like with these.
Clive,
I like this idea but how do ensure that there is no trace of gas in the cylinder before cutting into it? Is there any risk of explosion?I just made this for burning sawdust and bits and pieces, from a gas cylinder. Learned how to use a DC stick wealder in the procsses.they are cheap to buy and very small. I am going to slice the top off next year and fit a removable flat top and also a grill for BBQ But I also have a chinese heater and use red diesel from my local garage.
You fill it full of water, There are loads of videos on youtube on how to make them and what to do to make them safe. And a DC stick wealder they are really small and light weight and cheap chinese ones about £55 upwards, Mine is made in GermanyI like this idea but how do ensure that there is no trace of gas in the cylinder before cutting into it? Is there any risk of explosion?
My experience with a 5kw diesel heater is that it will make a difference in your 7 by 3.5 shed. The better insulated it is the bigger benefit you will gain.I'm very interested in a diesel heater for my 7x3.5m shed. I've read around them for months but will still not commit, reading this post has rekindled it for me.
I would be in favour of taking the supply air from inside. Why not?Could someone answer some basic question for me please.....
1. My thinking is to mount one externally and so both intake and exhaust would be outside any working, indoor space.....as the intake air would be cold (and so not be warmer pre-circulated air if the device was internal) does the efficiency of the heater then drop significantly?
I've not seen anyone insulating the exhaust, I've seen them heating water with it, or heating sand in a bucket, even putting it through a radiator to squeeze every calorie out of it.2. I've seen/read posts about people insulating the exhaust (where they've fitted them internally) but surely this then stops the room from benefitting from the heat radiating from the waste exhaust gases? Isn't that a trick missed?
There could be anything from zero to 20 or more degrees difference from inside to outside.
Could be hard to make up.
Mine is exposed for 3-4 ft to let the heat into the room and then exits through the wall.
The controller board was toast so I bought a Meross thermostat power switch. I removed the broken board and with a bit of trimming got the Meross to fit in its place. I know have a thermostat control with HomeHub connectivity for my workshop heater. It also has a frost guard and power usage monitor. I can also see the temperature my workshop is from my phone.Unbelievably my oil filled radiator failed yesterday. It’s been powered on in my workshop for years now, using the thermostat to provide frost protection and winding it up when I’m in there in the winter. I went to crank it up yesterday evening and the display was just flickering. I might see if I can bypass the inbuilt thermostat and connect it up with an external temperature control.
I think you'll be fine, my "shap" is almost twice the size of yours and it helps, but don't expect too much, you won't be working in your shirt sleeves if it's zero outside.Thanks for the reply. I think I'll take the plunge and treat it as an Xmas present to myself. My shed has very nominal insulation and the thought of emptying it to update it makes me shudder.
They are finely balanced units. I put a longer exhaust on mine and it doesn't start up so sweet.I like the idea of heating sand.
I also like the idea of using a rad but wouldn't there be a risk of inadvertently trapping some exhaust gases internally?
Go for it, you won't regret it.I think I'll take the plunge and treat it as an Xmas present to myself. My shed has very nominal insulation and the thought of emptying it to update it makes me shudder.
