Jameshow
I would have thought so, but only on my drilling experience. Not used one in a router..
Its generally accepted that a CNC'd MFT top is the most accurate,....and those holes are all done with a routering process.
As much as I quite like the idea of the Parf system, I just cant see the cost justification......I mean, in reality, just how many tops are you going to need to produce over a period of time..?
If you plan on using the MFT top as a sacrificial top and cut into it ( as I do), you can double its lifespan by just flipping it over and using the other side.
If you are not going to be using it sacrificially, it will last for years & years.
I have a Festool MFT3 and I've had it since 2016.....it still has its original top and I have yet to need to flip it over.
I also have a 2400mm x 1200mm MFT top that I use a lot for cutting & clamping on....Its more than 4 years old and is also still on its first surface.
I'm sorry, but I just dont see the justification for the Parf Guide system.![]()
Your experience of a CNC business with regard to accuracy & price is completely different to mine Mike....
My 2400 x 1200 MFT top cost me £100 in early 2018, and that included the price of the MRMDF sheet....!
Mine is bang on square and the holes are a really nice snug fit for all my dogs and clamping elements.....I did give him one of my tall Parf dogs to use to gauge the size of the holes I required. There is no slop whatsoever and I've never found the need to use any fixing knobs underneath to hold any of the dogs in place...![]()
It must all depend upon the quality of the CNC machine being used, trouble here could be if a company has invested a large sum into such a machine then they will be looking at returns and the best way to get a good return is to do batch work so minimising down time and setup. I have seen this many times, one job that stands out was getting some exhaust header flanges laser cut, it would have only cost slightly more to have twenty cut compared to just the two but why have things you don't need laying around! Looking at these MFT tops it would be easy to get people together to get a batch made but then you have the shipping cost which are not so cheap for bulky items.
What was wrong with Amphenol, they do an a huge range of mil spec connectors in many ways and current ratings?When I was designing equipment, I needed two round connector backshells for a special purpose cable
Only issue for me in some applications was the size and weight so another great manufacturer was Deutsch.
This is also the case in Italy. Italians cannot believe that someone in the UK would build a kit car or a telescope.You certainly have more resources available to you in the UK, as I have learned with other projects. Privately owned hobbyist workshops are not common in my area, or maybe in all of Germany, so the availability and cost of related services and tools is limited or prohibitively restrictive.
Two of my neighbors were convinced that I was operating an illegal Schreinerei business (furniture and joinery shop) because of the machine and wood deliveries to my house. The concept of anyone actually making their own furniture, fixtures, or furnishings, rather than buying it or contracting with a Schreinerei is alien.![]()
But a lot of kit cars were modeled on Italian designs!Italians cannot believe that someone in the UK would build a kit car or a telescope.
Take the Lancia Stratos, an iconic Italian rally car. The 2 companies producing affordable kits are both English. When you need parts where do you look, despite the parts being from other Italian cars, the UK.But a lot of kit cars were modeled on Italian designs!
Then you have to ask yourself if we have so much ability then why as a country are we in such a mess, this is because those that cannot do just have jobs involving talking and end up in management which we must be the worst in the world for. The british cannot manage as shown by so many companies and sporting things all using foreign managers. One day we will realise that it is the engineers that make a company and not the management.
Amphenol make what people have already asked for, if you’re doing something new even their catalogue is missing what you needWhat was wrong with Amphenol, they do an a huge range of mil spec connectors in many ways and current ratings?
Having used the CNCpro jig, the tape is used to fine-tune the hole size - this isn't because their jig isn't accurate and you probably wouldn't need the tape if your guide bush and cutter were exactly 30mm/12.7mm respectively.Straight away i didnt like the look of the CNC pro jig. It might have been the quickest, but that alloy wrap looks too flimsy, and i can see it catching the edge of the jig and getting ripped or somehow messed up. Plus i dont really see the need for 'adjusting' the holes. That maybe reflects more on their design being sloppy than with the other 2.
Yes, the CNCPro jig with a standard 30mm bush and 12.7mm bit makes a 20.2mm dog hole - that’s the Festool MFT standard hole size. There’s a long back story to this and I wrote a blog post covering the details on the member website, but short version, Festool never intended the MFT to be used with dogs - it was a table for crosscutting and clamping - and to this day Festool have never made or supply Benchdogs.Having used the CNCpro jig, the tape is used to fine-tune the hole size - this isn't because their jig isn't accurate and you probably wouldn't need the tape if your guide bush and cutter were exactly 30mm/12.7mm respectively.
The the aluminium tape plus a few test holes let you decide how loose/tight a fit you want for your dogs. I had no problems with tape 'catching the edge of the jig and getting ripped or somehow messed up', in fact it ended up so smoothly moulded to the guide bush that I had difficulty locating the end of the tape to remove it.
