Phil Pascoe
Because they don't need a slight taper?
I guess because anything less than about 7 degrees (isn't it ?) makes a self locking taper and the dogs would have to be knocked out from below. Other than that it's a great idea. No more slop.Why don't they make the metal ones with a slight taper?
They'd just have to be long enough to get at them with a little hammer. Being tapered they could be as long as you like.I guess because anything less than about 7 degrees (isn't it ?) makes a self locking taper and the dogs would have to be knocked out from below. Other than that it's a great idea. No more slop.
It may well be - but it makes no difference if the dogs/holdfasts don't go into the holes.Could be your top is too thick!
aren't bench dogs adjustustable so their height so they can be lower than the workpiece? If you have a tapered dog it would get tight at a set height and that's all you can do. Not really practical on my bench to have tapered as if i had to knock them out from below it would be a proper faff as I've got an english workbench with a 12inch apron down the front.Thinking about tapered dogs again:
Could be the answer to all above probs, assuming the dog-hole is accurate to start with.
A tapered dog would line up precisely with the non tapered hole, on the side where pressure is applied.
Removal could be easy if it was drilled to take a tapered drift as many morse tapers are.
One size dog would fit accurately into holes within a range of diameters.
If accessible from underneath a long dog could be tapped out easily.
Why are dogs round? Isn't clamping pressure always either along or across the bench? A trad planing stop is always square - which helps keep the workpiece steady.
PS have never felt the need for a a so-called MFT myself and all these doggy probs would put me right off! What next, poo bags?My trad bench is already multifunctional - you'd be surprised at some of the things I've done on it.
Wooden dogs. Trimmed to fit.aren't bench dogs adjustustable so their height so they can be lower than the workpiece? If you have a tapered dog it would get tight at a set height and that's all you can do. ....
Not sure what you mean. Do you mean have multiple sets with different heights? a taper will only fit to a set depth, you can't just push it further in regardless of what it's made from.Wooden dogs. Trimmed to fit.
You could have a collection of tapered wooden dogs and shorten them as necessary to fit the workpiece.Not sure what you mean. Do you mean have multiple sets with different heights? a taper will only fit to a set depth, you can't just push it further in regardless of what it's made from.
