The Ryobi and Record tables are the same and identical to the old Woodcut Trading sliding router table, except for one or two wiring details. I have the Woocut and it's a reasonably good table with some caveats:
1. The fence is diabolical and needs a bit of work on it to straighten it up. I've fitted a wooden face plate onto mine which now makes it work properly. The dust extraction isn't too bad (above the table - none below)
2. Fitting the router beneath it is a bit of a faff. Once in the router is best staying there. Not a table to continuously swap the router in and out of unless you have a suitable fixed-base router (Bosch, Porter-Cable). Also a bit tight for tightening the collet nut (at least on the DW625 and Bosch GOF1700) - ideally you'll need a one handed design (like those two).
3. Both the fence and the clamp on the sliding table have a tendency to flex (maybe I'm heavy handed?) which is something to watch out for. I reckon the fence needs to be binned and a piece of angle iron (or wood) substituted
4. You'll have to rig-up your own dust extraction for under the table.
5. The thickness of the cast-iron table robs you of some depth of cut, so this table is one to consider using a 1/2in router with and a spindle extension piece (when required)
Then again this isn't a spindle moulder and I'm therefore prepared to accept its little foibles. It's a heck of a lot better than Record's last all-steel enclosed router table. On the upside the table is stable and heavy, of a reasonable size for a router table and the sliding table allows you to build your own jigs for machining small tenons, scribed frames, etc. Overall probably one of the better attempts at a router table.
Scrit
