Router table build 0
Dauph
UKW Supporter
26 Aug 2024
e177dz
Hi all.
I'm most of the way to finishing this. It's a little shonky, but it's all square solid and level, and the micro adjustment I was hoping for works.
One question: Does having the cable bunched up in the corner like that present any risk? I know their can be issues with using power cable wound round itself (condenser maybe?)
I understand the risk with power cables, usually wound on a drum for an extension lead, is that the cable could heat in a way similar to a traditional bar fire due to the magnetic field created.
I would not personally be too concerned as it is wound loosely and typically a router is worked intermittently for short periods, at a power level well within the cable capacity.
If bothered just check for heat build up after use - I would expect little or none.
Probably not, but I would just pull it through and cut it to a tidy stub.
You have the skill to wire it so I imagine you would find it easy enough to replace the cord into the tool if you want to go back to handheld use in future. Or just put an inline plug and socket like a neutrik in the cord so you can easily hook the router up to your table or unplug, and reattach the long cord.
Good idea. Solves a couple of design niggles. Cheers
Hi all.
View attachment 188331View attachment 188332
I once had an extension cable on a drum go on fire, when using a 2kw heater. (IT wasn't mine, it was in someone else's garage).
Hi all.
Looks good and solid.
What did you use as the raising mechanism below the router? And what did you do about dust extraction from the box?
Hi, it's this https://www.amazon.co.uk/dp/B09TFLD62W?ref=ppx_yo2ov_dt_b_fed_asin_title
I lift the router to the rough height, lock it off, then raise the scissor lift up, then unlock the router and use the lift for final adjustment, then lock the router again, rather than use the lift for the whole process. It is a little flimsy so I try to keep the weight off it as much as possible. It is a bit off a faff but it is pretty accurate. I also put a bit of ply on the top plate as it flexed a bit. (hope all that makes sense?)
Dust extraction is just a hole near the bottom of the box. It could be better to be honest. I need to make an extraction point for the rear of the fence as well.
Thank you very much for the link, will have a surf closer to home, nice solution.
My Ryobi router has a treaded shaft with 2 nuts to adjust the bit height, easy. (started making a noise, so packed away for now)
Bought a Makita RP0900, nice router, BUT, there is no height adjust, only the lock and the switch does not have a hold button!
Switch was modified with the latest technology - some wire and wooden peg :)
For height adjustment I ended up with a scissor jack (heavy duty). Then needed to relocate the power socket out the way.
Concocted a turning handle which works well White disk on end.
Dust extraction is at the back of the baffle plate, gap at the bottom. Installed another pipe to connect to the router dust spout, not that successful. The fence also has a dust hole.
The modifying/repair/changes of the router table is on my to-do-list.
Think I'd be more concerned about the router overheating than the cable with the router inside a box. I'd put the dust extraction from the top and keep the router enclosure open.
Good point.
My vacuum suction, 3 speed 3000w industrial vacuum connected to the back, pulls in air from the router hole, fence hole and the front cover which is perspex with 20mm holes drilled in.
The only time I find the router gets hot is when doing 32 biscuit slots, 4mm, one after the other.
