Compounds for buffing / polishing
Rewound
27 Dec 2022
UK
I have the chesnut kit with its brown and white compounds that I have found to be good
ai tells me that the equiv grits for these is Brown 400-800 and White 8,000 - 12,000
We have just been given a dual wheel bench grinder fitted with a couple of mops, one has been used for Brown and the other for White
the compounds that came along with it are all "Silverlink"
Coarse Black (220-400)
Coarse brown (400 - 800)
Fine Blue (800-1500)
Fine White (8,000 - 12,000)
and there is also a small green compound with XG imprinted on it
(the grit equiv is what ai tells me)
Do you think the Silverlink Coarse Brown and the White are the same as the Chestnut ?
if ai is in the 'ball park' (and I don't alway trust ai) what a big jump to go to the white
what's your thoughts on the Silverlink compounds and how would you use them - is it worth buying two more mops one for the blue and one for the black ?
just going back to the original post - we already have the items I listed, they were given to us, I am just trying to ascertain how abrasive they might be, and how they might compare to the Chestnut ones I have been using for some time
Your initial search results would appear to confirm they are similar. Use them and find out?
The gap between coarse and fine is rather large. Linked earlier is a guide to Menzerna compounds.
You could choose an intermediate compound for which you’ll need another mop. Here’s the guide again.
https://www.thepolishingshop.co.uk/guide-to-menzerna-compounds-for-woods-plastics-and-lacquer
You could just start from scratch (pun intended) the Mini bars aren’t expensive to try.
Uh oh a sharpening thread! Well, I guess I qualify as experienced carver, so here’s a controversial two pennorth. Sharpening is a skill so there’s no magic bullet. Honing is pretty much every time you change tool, but is usually just a couple of seconds to refresh an edge. If an edge is too far gone to hone then sharpen with a bench stone then hone it, if it’s chipped then grind it with something a bit more substantial. I use a belt sander. A ship wright taught me this and his edges were the best I’ve ever seen. It grinds a flat bevel not hollow-ground. Incidentally I have tried most’systems’ and bought several but my Aldi belt sander with cheap medium belts is the best grinder I have used. Little tidy up with a stone and a hone and you’re away. Best honing compound is Autosol chrome- if it polishes chrome to a mirror finish it’ll do the same to a chisel/gouge. When grinding, heat is the enemy, keep a very light touch and dip the tool into a mug of cold water frequently. With all sharpening have a light vertically above the tool and watch the shadow under the edge, when there’s no shadow the bevel is down flat, you should feel it engage when it’s down; learn to use short movements so the tool doesn’t rock
Don’t be precious about the angle on the tools, you are not a standard size, you don’t need to keep your gouges at a standard bevel. I like my blades ground very fine, they cut easily but they need sharpening more often than standard. I experimented for a long time to find the angles I like but even several re grinds never took off enough steel to render a chisel unusable.
its a buffing polishing thread - no one has mentioned sharpening chisels
(although a buffing wheel will give a hand held chisel that final razor edge after the normal sharpening routine)
