Nelly111s
You mentioned no tail vice due to it being complex. I’m in the “research” phase and am looking at the HNT Gordon tail vice. Easy to install, looks good, to.
I pretty much did as you are planning to do. Knock down is a must unless you know you will never have to move it. The wracking resistance is in the size of the shoulders of the long stretchers. The top and bottom end rails are glued joints and the long stretchers are attached with a nut and bolt like a bed bolt arrangement. Mine is all scrounged wood so the top is pine and the legs are blue gum. Keep the top halves narrow enough to go through a thicknesser and you save a load of sweat.
View attachment 105094View attachment 105095View attachment 105096
Enjoy the build.
Regards
Just looked at it. Looks neat, but is the vice held on by those tiny screws and the brass dowel? Wouldn't that put pressure on those small fasteners when you tighten the vice or am I missing how it is actually held?You mentioned no tail vice due to it being complex. I’m in the “research” phase and am looking at the HNT Gordon tail vice. Easy to install, looks good, to.
I have a link to a video somewhere, I’ll see if I can find it.Just looked at it. Looks neat, but is the vice held on by those tiny screws and the brass dowel? Wouldn't that put pressure on those small fasteners when you tighten the vice or am I missing how it is actually held?
Good thing is it is retrofittable, so I could do it at a later date when funds allow it, if I feel the need. But very very neat indeed.
It was actually on Instagram. A guy called Ramon Valdez (ramonartful on IG).I have a link to a video somewhere, I’ll see if I can find it.
Couple of questions:
1. When you say the top is bolted, did you elongate the holes on the bearers to account for wood movement?
2. The bench bolts to hold the long stretchers, would you be able to share a picture of that as to where it is?
Please.
Glad you brought it up. I was looking at it last night. At 28mm DIA, I thought it was pretty decent.Leg vice - metal screw and a wooden guide. Takes a little longer to wind in/out than a wooden screw, but had the advantage of being bombproof, relatively cheap and easy to source.
e.g. Veritas Tail Vice Screw
I have that screw. It's a beast.
Not nearly as refined an option as the benchcrafted offering, but no mortgage required to fund it either.
The old style massive workbenches also offer a lot of shock absorption with impact loads.
