Mark A
Hi chaps,
Good news! The worm is out of the box!
Here's a picture to prove it.
It transpires the shaft upon which the worm is fitted is splined, and so to disasemble it was just a case of knocking the shaft through. I had actually tried doing that a couple of days ago, but was just not heavy-handed enough as I was worried about cracking the casing or damaging a bearing.
I did, however, discover after taking apart the gearbox that a small chunck of casing around the rear bearing (through which the shaft passes) has come off at some point in the last 70 years and the rubber gasket has started to perish. The gearbox oil has been slowly seeping through, and is the reason why the motor casing is so filthy.
I have a tube of gasket sealer. Is there any reason why I shouldn't use some in conjuction with the perished rubber gasket?
Mark
Mark
