Thanks to everyone for the advice - having purchased a single phase 2hp motor, thought it might be of interest to discuss how I fitted/tested it on the AGS 10. I’m just trying to fit it so that i can be sure that everything is ok and that it will work before I strip the machine and replace parts/ paint it etc.
Following the advice in the thread, i decide to go with a simple single-phase update rather than the VFD/three-phase. VFDs that work at 380 volts are now available and while expensive might have worked with the existing non-deltaable motor (is that a word?). However, i had no easy way of checking the motor before committing to the VFD and I’ve read a few things that suggest older motors insulation on the windings might not take well to using with a VFD. That left replacing with a delta-able 240v three-phase or a single phase motor. General consensus was that there was going to be little benefit in the VFD for a table saw - breaking and soft start might be nice, but reverse would be positively dangerous! Breaking would require some large resistors outside the VFD. In the end, single-phase would be cheaper and easier to do.
I got lucky and found a TEC motor on ebay being sold new-other by a company selling pumping gear that apparently overstocked during the pandemic. I got it for £50 quid plus £17 for postage - bargain! It’s 2hp (1.5KW) and 2860 RPM which by my calculation should end up around 3500 RPM - or thereabouts.
Once the Motor arrived, I lined it up with the existing one and was delighted to find that the distance from the mounting plate to the centre of the spindle was more-or-less the same. the old one had developed a bit of a lean but then it only had a pressed-steel foot
This would help keeping to the original belt size a lot easier if the motor can end up in the same place. I marked where the centre of the shaft came on the old motor when mounted on the plate ( when I got the saw, the motor wasn’t mounted so i placed it in roughly the right place, selecting what appeared to be the right set of holes from all the various ones in the plate)
Then i mounted the plate back on the saw and clamped the new motor to it to check the position:
There are quite a few holes in it now so i guess it’s had a few motors in the past. I might look to weld these up before I paint it, just to make it look a bit tidier. Once i got it roughly the right place, I clamped a straight edge to the spindle pulley and then jiggled the motor about until the straight edge sat straight against the shaft. Then I marked the motor position with masking tape (couldn’t get a straight line to the holes in the foot).
All good, so took it off and drilled the holes and mounted the motor to the plate with some new bolts and nyloc nuts.
Wired the motor with some new flex. Needed to change the wiring as it was going to be running backwards in its out-of-the-box configuration. Not a big problem as it had the diagram of how to re-arrange the plates in the lid of the connection box. I did find that I had to move the connection box a couple of times. as delivered the cable gland was facing the rear of the motor which wasn’t great and the box is wider than it is long. I unbolted it and moved it round so that the cable entry was towards the front (i.e towards the Switch box). However, with it in this position, it fouls against the lower cabinet. I swapped it 180 degrees as the connection box is not centred. It now does lower all the way. This is an important consideration as the motor is pretty huge - bigger than the 3-phase original (i.ve read that in general, 3-phase motors tend to be a bit smaller so that might be another consideration for the VFD/single phase debate).
I got a new SPZ three-way taperlock pulley to fit the new motor. Oddly, I had in my box of parts two 587 v belts and one 612 Which was odd. On the balance of probabilities I fitted the two 587s so I could at least test. Tensioning is actually pretty easy as simply letting the motor mount drop tensions the belts under the weight of the motor. Powered it from the wall with a 13amp fused plug to test and it ran great. Spindle bearings seemed ok but the blade rang a lot, but then its a pretty old simple blade on it. Starts quick and doesn’t seem to impose a particularly heavy load (lights don’t dim
) It also stops much quicker than I was expecting (quicker than my current saw in fact)
It’s odd watching it without the table top on - it looked really fast so thought I’d measure it. Used a strobing iPhone app that uses the camera and the flash. I scribbled some black sharpie on the blade and also stuck a strip of masking tape on the spindle. It did a great job and I found it was running at 3954 RPM. I guess the slight change was due to the slightly larger metric Pulley rather than the old imperial one on the old motor - i went for the nearest.
So really happy now - got a quiet motor installed and it works fine. I know the belt size so will get three new belts and a nice new blade.
I’ve stripped the saw down today which went very well indeed. Not a single stuck nut and no chipped teeth or broken/chipped cast iron. I’ll probably look to replace the spindle bearings and maybe get the face machined as its out by about 0.1 MM. Doesn’t sound a lot but at the top of the blade is considerably more, and while its in bits it seems sensible. Will probably change the bushings for the tilt while am at it as there is some play in there.
I also need to get a new NVR. There is evidence of some burning/Charing in the past to the front of the machine, but the inside of the switch box looks ok so I guess it was replaced. The controller on there is for the old three-phase (DOL?) so I don’t think.I can use it. Shame as it does look nice in its metal box - very ’period’. Perhaps I can adapt something From one of the ugly grey plastic boxes. Anyone ever done that?
Anyway, hope my ramblings may be useful to someone wanting to do this in the future, and thanks so much for all the comments and advice.
all done for 95 quid (So far…)
