Yes.
Importantly, if used as a variable speed drive the box has to be dedicated to and programmed to match one single motor.
It is acting as a VFD which also performs a step up of the voltage from 240v single phase in upto 415V three phase out.
You can't connect multiple motors when you are using variable speed and you can't switch the drive between single motors without reprogramming the drive with the electrical parameters of the motor each time you change.
