I have been asked to look at a leaking ballcock valve in a toilet in a community building. The cost of calling in a plumber is prohibitive for the charity involved, but the cost of messing it up and then calling a plumber is punitive! So I am asking for specific advice from forum members on the following points.
Photo of valve:
The building is around 60 years old, and most likely this ballcock has not been touched since new. The cistern is bakelite, or something very similar. Amazingly ( and fortunately ), the stopcock for the cistern works fine, so the ballcock valve can be removed for repairs.
The float arm moves up and down quite freely. I suspect either the jet inside the valve has become gunked up, or the small washer on the end of the sliding piston has perished, or both.
Firstly, will spares still be available? If so, will they need to be imperial? If not, can modern metric parts be cut down?
I propose to leave the feed pipe in place on the cistern and to remove the ballcock by loosening the nut indicated by the red bar in the picture. This is to minimise risk of damage to the cistern. If this is not a good idea, why not? Suggested alternative? I need to avoid torque on the entry pipe on the right of the photo.
Any tips for loosening old brass joints like this? I have all the necessary tools, along with fancy WD40 etc. I am not a trained plumber but a reasonably competent household DIY guy. I have replaced pipes, copper hot water tank heaters and such like in the past.
Thanks in advance for your time and consideration.
Photo of valve:
