Job done! Thank you all for advice.flush it out 'properly' and add fernox?
I hadn’t expected it to take as long as it did. I guess that draining a system in a bungalow is likely to be slow. Ok to start with but once the water out of the feeder tank it all slows down. I did find a drain off valve below an obscure radiator. So much gunge to be removed from the feeder tank as well. When all turned back on I had an F23 boiler error (Vaillant) that cleared on a fresh restart, and it all works. Hurrah!
