DannyEssex
Richard T":gnk1pztj said:So ... Danny, how are your chisels coming on?
I got lost by page 7 :|
Cheshirechappie":2x1dqbze said:Just thinking out loud, as it were.
I wonder if the particle shape of the abrasive has a significant effect?
Cheshirechappie":2ztyl1yn said:Just thinking out loud, as it were.
A stone made up of hard, sharp-edged particles would tend to act mostly as a cutting tool, shearing metal off the sharpened surface, leaving gullies and peaks on the abraded surface. A stone made of hard, rounded particles wouldn't cut so much, it would burnish a sharpened surface by smearing metal (plastic deformation) - perhaps tending to compress the high points left by the previous stone into the gullies it leaves as well.
So, whilst the abrasive particles of the two stones may be of similar size, the two stones would behave very differently in sharpening, and give different edge qualities. One rather cut and ragged, the other more burnished or polished.
Corneel":iilumeda said:I'm not so sure about the fractures being the major cause for edge dulling. As far as I can see, a worn edge is very rounded. When you get nicks in the edge, you should enlarge the sharpening angle. A well wearing toolsteel in a handplane with a large enough sharpening angle shows very rounded shapes after using it a lot. In my opinion, abrasion is the main cause of edge dulling.
Corneel":3ovzk2u7 said:A quick search reveals load sof studies to cemented tungsten carbide tools. The main wear mechanism seems to be removal of the cobalt biner between the carbide cristals, indeed through mechanical wear and micro cracking. In wet wood chemical attack of the steel plays an important role. And high silica content increases the mechanical wear. High temperatures are weaking the steel, but I don't think that plays a role in handtools
But I can't find anything yet about carbon tool steels. Handtools don't use cemented tungsten carbide.
Really?Corneel":1fv54u8b said:Wait a moment, I'm completely confused at the moment. ...
Wos this "clotting" tip?woodbrains":1fv54u8b said:..... The forces and temperatures generated at the tiny clotting tip of a hand plane or ........
re attached to spiny things ....
Mike.
