Don't bother. I watched the app when I turned on the roast today. A few minutes of 3.6kW as the oven ramped to 200C, then it just flipped back and forth between 2.2 ish and 0.5kW as it cooked using the fan. After the first 10 mins of full power I'd say it averaged about 1.5kWNext time I do a roast should I sit there and time the red light on/off durations? Wouldn't change anything, would still cook but at least I would know. It could get to be an obsession ......
I did a silly intellectual exercise the other day thinking about energy storage. Imagine using Potential Energy as a form of storage. I don't have a lake to use for pumped storage and my garden's small, so how about using surplus energy to raise a heavy weight and then let it down to turn a generator and get back the power when you need it.
Ok. What if we could use the whole house as a mass. I guessed 100 tons and let's raise it 1 metre.
Energy = force x distance
= 100 tonnes x 1000Kg/tonne x 10Newtons/Kg x 1 metre
= 1,000,000 Newton metres
(1 Newton metre = 1 Joule of energy)
Now a quick lookup tells us 1kW hour = 3.6 million Joules of energy
So assuming no losses and a perfect mechanism to do this silly experiment, I would be able to crank my entire house a metre into the air in just 17 minutes using only a 1kW motor for an energy cost of less than 6p.
Wow !
It demonstrates that one kWh is a big unit of energy
