Record StaySet - opinions
worker
11 Jul 2021
UK
Hi
Does anyone use Record StaySet planes/irons? What are your thoughts on them?
Basically wondering whether it's worth buying a StaySet plane for the sake of not having to dismantle the iron and chipbreaker each time for sharpening (which I find myself having to do quite often for oak).
I have a couple of stay set planes, bought for the plane rather than it being stay set. Can’t really see the benefit, doesn’t take much effort to remove the cap iron to sharpen then re assemble. I’ve just upgraded my 5 1/2 to a hock cap iron and Ray Iles blade, it’s made a big difference.
Not bothered personally. Use two or three irons and cap irons already set up. just change them, and then have a session sharpening. Personally I always keep the sharpening angle short, grinding it back fairly regularly, so they don't take much to sharpen and hone.
I use a stay set plane as one of my daily users. For me it's not a deal-breaker in regards to sharpening and the lever cap needs to be stiff to ensure the removable part seats on the iron efficiently. However the thicker cap iron does feel nicer in use imo.
I've got a couple with Clifton stay-set cap irons. Does slightly speed things up if you do trad sharpening "a little and often" and they do fit well by being pivoted and not sprung. Trad sharpening removes least metal so they do actually stay set for some time.
It's not that obvious but they also seem to be pivoted side to side in the slot with the pin, so even if the blade is twisted or otherwise out of order, the cap iron will still sit tight at the sharp end.
They are not essential but if you have one it's worth hanging on to.
I've got a couple with Clifton stay-set cap irons. Does slightly speed things up if you do trad sharening "a little and often" and they do fit well by being pivoted and not sprung. Trad sharpening removes least metal so they do actually stay set for some time.
Trad sharpening removes less metal???
That's not true is it Jacob.
Yes I've poked the bear😂
Absolutely is true. Main thing is to keep things away from powered grinders - they are the blade destroyers.
Not quite the same but it's a bit like sharpening a knife with a steel - just a light touch almost every time you pick it up. They last for life and need no great grinding and fettling.
On crazy sharpening - one thread which stood out for me was about sharpening a serrated bread knife. They went into minute detail about radii of serrations, different files, difficulties etc etc, completely ignoring that the whole point of the serrated knife is that it is really easy to sharpen with just a few passes with a steel. All it would need for life, which may even last several generations.
Stanley/Bailey design is all about sharpening more than anything else; thin blade needing no power grinding, quick and easy to remove and reset, easy to do just a light touch, a little and often..etc.
Hope that helps!
Hope that helps!
You've deviated into grinding, I replied to your comment about sharpening.
Modern sharpeners grind "primary bevels" relentlessly. I don't. You don't need to if you take control of the process.
Still deviating.
Don't worry about it - I only do it in the privacy of my own workshop! Well since I'm retired that is.
PS come to think - I used to do it out on the job too. I didn't turn up with sheets of granite, plate glass, reams of wet n dry, several stones, a collection of sharpening jigs, a Sorby pro edge, but still managed to keep tools sharp, with one oil stone and very little effort! How could this be? :unsure:
A couple of stones, a honing guide, that's all until the blade needs grinding, always a hollow ground blade.
I never need to grind, unless it's damaged etc, and never have a hollow bevel. Quite the opposite - it tends to end up slightly rounded under, from the edge at the chosen angle (usually about the universal 30º).
