Bod
Does anyone have experience of using a Record 145 holdfast in a 146 collar?
I have 2 145s, but only 1 collar, however I have 3 146 collars (1 x Record 23mm dia. 2 x Axminster 25mm dia.)
I cannot find a supply of the smaller collars, the larger is not a problem.
The 145 has 19mm dia. stem. 146 is 22mm dia.
I have 1 146 holdfast, so too be able to use either size would be an advantage. But if the 145 holdfast won't work reliably in a 146 collar, then I shall have to think again.
Bod
Bod
