Idefixes
Hi all i read all about TS200 on this forum. Actually i have a Rexon BT2502AE
This table saw suffurring from a to high balde/motor group flexibility. So when the wood is a little hard, when the blade as to many teeth, the cut goe's to side...that's not enough good for good box assembly. So i need to purchase à new machine to do a good job. I want to purchase a Festool TS55 with 1,40m rail that i could use on job site. But for little pieces repetitive pieces the festool will perhaps not be enough confortable in use so i "little" saw bench as Axminster TS200 could be a good soluce for me. So the main question : is the blade/bade pullet rigid enough to provide a precise rigth cut. The other issue on my rexon is that the tilting angle setting is not stable, what's with TS 200?
best regards Marc
best regards Marc
