andy king":1itgisyq said:
Morning All,
If I remember correctly, the negative rake is there to try and minimise the saw from racing across the timber on a pullover mitre saw.
These are meant to be used by pulling the head over the work, then dropping into the work from the front and pushing back through the work, not pulled through it.
If it's pulled through, a positive raked tooth will grab and pull quickly which can take you unawares and lead to an accident.
On a static head chop saw you don't have the problem as you address the work directly over it, hence these are normally fitted with a positive rake.
Andy
Interesting you say this Andy, because that was my assumption until I got my Elektra Beckum KGS 303.
Reading the manual, which I now do as part of the new toy bonding ritual - also points out any misconceptions I might have had about even the simplest tool - I noticed a written instruction and diagram clearly showing the user to start at the back and do a climbing cut through the workpiece, ending the cut with the blade coming to the point nearest the operator.
Now this seemed odd to me, especially as I'd seen plenty of other users doing the opposite action, namely pullover, chop, slide back while cutting, then lift up, powering off. Obviously the climbing cut could cause runaway toward the user, but in practise it does not. With the saw design the way it is, the climbing force is easily managed with the high leverage handle.
Benefits would seem to include the ability to see the cut in progress, and it would appear easier to hold the workpiece down by hand in a mitre cut, without it trying to crab along the fence in the direction of cut. It also seems to prevent "explosive" breakout at the back of the piece.
Martyn
PS the saw ships with a slightly positive rake blade, which they advise for wood. The negative rake blades are generally only for laminate and aluminium.
