Mark A
Hi chaps,
Our house is in a valley with tall trees up either side. The weekend before last a tree came down in high winds, blocking the farmer's lane running along the boundary and crushing a section of hedge. Fortunately, this particular tree was about 40 yards away from our heating oil tank, but next time we may not be so lucky.
A local steel fabricator is popping round tomorrow to take a look, but I'd like a bit of advice beforehand.
I am envisioning four steel columns bolted to concrete footings, supporting beams on top. I may fix a sheet of corrugated steel on top at a later date.
Would bolts be adequate to join the components together, or would welding be best?
With regards to attaching the columns to the footings; should studs be set into the concrete while it is being poured, or can studs be adhered in place with chemical fasteners after the concrete has cured?
Cheers,
Mark
Cheers,
Mark
