Speed regulation:
The speed controller (1.9/2.3) provides infinitely variable
setting between 2000 and 4800 rpm of the speed of the saw
blade. This enables you to optimise the cutting speed to suit
the material.
Constant speed:
The pre-selected speed remains constant whether the machine
is in operation or in neutral position.
Diode display:
- The green diode (2.2) shows the operator that the machine
is in operation.
- The red diode (2.1) shows that the motor is overloaded by
about 70 %. If the motor is thus overloaded for a lengthy
period, it is switched off by the safety electronics.
Our recommendation: If the red diode lights up, lower the
feed power until the red diode goes off again. You are then
working within the allowed load.
