johnelliott
Aragorn":l862zbg9 said:John, this would vary depending on how you set up the cams that keep it snug to the guide rail.johnelliott":l862zbg9 said:Another thing I've noticed about the new saw, it's trimming the rubber strips on my guides, so it shows that the distance from guide rail to sawblade does vary from one unit to the next.
Not really, the function of the cams is to keep the wear pads cast into the baseplate of the saw close against the raised portion of the guide rail. The important factor here is that the relationship of the blade to the edge of the guide isn't variable by the cams which only act on one side of the guide rail.
It might be possible to insert shims into the base against the wear pads but I can't see any way of holding them there
