No worries Steve :wink: I do get carried away somtimes :?
Thanks for the scan Neil
It is as I suspected, no gearbox (rules out backlash) and no obvious feedback mechanism to control speed.
I think that they have either used a type of speed control called Armature feedback control or run it 'open-loop' (i.e. no monitoring of the speed) using a PWM drive system.
Armature feedback is notoriously difficult to get accurate speed moitoring from but it is the cheapest way to monitor the speed of the motor. Expect speed control to be around 8%. this type of feedback control may well produice the 'hunbting' reported here.
Open-loop is still most likely for these saws in my opinion although I may have missed something in the drawing. Open-loop speed control using PWM is very good and more than adequate for a circular saw
Tech bit for the interested - please feel free to ignore:
A motor and a generator are pretty much the same thing. If you spin a motor armature inside a magneitc field (field windings or permanent magnets) it generates a voltage and current. Motors are not as good as generators at this due to slight constructional differences.
Now, if the rotation of the motor is due to a voltage applied to it, the motor still acts as agenerator and generates it's own voltage opposing the 'driving' voltage (that you applied) - this is called the back-emf (emf, electro motive force, is just another term for voltage). The back-emf causes a current to flow in the armature windings in the
opposite direction to the current you are putting in to drive the motor.
It is very easy to measure this back-emf generated current and it is pretty much
proportional to speed. However, due to losses in the system that are varying with speed, the use of back-emf to measure and thus control speed is not too good and the control is usually within about 10% of ideal (best I have seen reported is 8%)
End of tech bit hope it wasn't too boring
Tony
who is waiting for Alf's cutting and funny comment on ' I do get carried away somtimes ' :lol: :lol: :wink:
