Post a photo of the last thing you turned
The cherry burl saga
Just a small offering today last of the two small bits. 20241007_131654.jpgthe top part I've used to make the second lid for the stumpy pot.so what was left over was pretty small. Then an idea occured to me that would incorporate the small plate. Heres what I've come up with20241007_125750.jpg20241007_125901.jpgand with the plate20241007_125703.jpg20241007_125640.jpgI have not glued it yet but this is were I'd appreciate you input. I've got ca glue epoxy glue the small two pack syringe type and titebond 3 waterproof wood glue. Of these three witch would be the best to use bearing in mind its for food use (egg cup) or should I be using something else. Thanks in advance
Road kill
I picked up a chunk of silver Burch that was in the middle of the road, did a rough turn to remove the bark and knots
After that I coated it with pva on the o/s edge then left it to dry.
Today I cut it in half and made these, some nice pattens .
    2.2 MB
    2 MB
    2.1 MB
    2.2 MB
Did you use a spinal Chuck /jaws for the trees?
Those bows made from road kill were a step out of my comfort zone. I normally use a face plate to start
These were turned using button/Cole jaws and Axminster a plus jaws, (much wider than my normal jaws)
Turn one bit reverse, turn some more and reverse and repeat..... lots of times
The ribs are a last reversed Chuck turn to ease out the bite mark from the hard jaws.
