@Doug B I feel compelled to not only pass on my compliments for another brilliant project, but the fact you have clearly not suffered from expensive gizmoitus.
My only comment, is, I prefer to use my cheap speed square, when cross cutting, on the leading edge..
Thanks @HOJ I can’t see the point of buying stuff I can easily make & I see track squares as expensive one trick ponies. I agree re the square on the leading edge most of my cuts are made like that I just prefer the opposite way cutting narrow pieces.
I was asked recently if I could re-pipe a towel warmer the original pipes ran around the bedroom skirting & didn’t look that nice. In the bedroom was an alcove that had a fitted wardrobe the towel warmer was on the other side of this alcove so I suggested removing the the back of the wardrobe & running the pipes in the void behind from the ceiling above.
On removing the back of the wardrobe we discovered the void was 300mm deep which got the customer wondering if we could utilise the space for storage, in particular for her shoes.
This is what I came up with
The parts were just cut up with the tracksaw, no fancy track square just a speed square.
To make the shelves adjustable I used my shop made shelf pin guide.
The shelves were cut to size with the router & another shop made jig my parallel guides
This is the unit fitted in place
& this is the finished article with the fitted furniture reinstated
Just wondering why you used the router to cut the shelves to size and not the track saw?
Fished shelves look great!
Thanks Paul, I use the router as that leaves a machined clean edge on both pieces cut so I can just keep moving the track across & make another cut. The tracksaw doesn’t leave a good enough edge on the waste side to do that.
That’s really interesting. I’m surprised you don’t get a clean enough edge on the offside of the cut. I’ve not had much of a problem with that. I can see how the router would avoid it if it is happening. Good tip. I’ll remember it if I get the problem
I posted the build of a trestle dining room table in Projects. For those that missed this, here are a few photos.
The design is my own. The base uses elliptical sections, in Jarrah ...
Note that chair to the right is one of two I built, based on the Japanese-Danish DC 09. The aim of the table design was to mesh with these chairs as well as a set of vintage bentwood chairs we have.
The elliptical top in Rock Maple ...
Regards from Perth
Derek
A set of four boxes, all made with hand tools only (although some of the timber had previously been resawn on a bandsaw). They were made while on holiday in Brittany, using my Travel Tool Chest & Workbench. The one on the left (which has a couple of drawers) isn't finished yet as I need to turn a couple of walnut knobs when I'm back home. None of them have had any finish applied (the tea caddies will get mineral oil, the other two will get my normal default of Mike's Magic Mix).
The drawer box is American black walnut outside, with maple drawer fronts and sweet chestnut drawer bodies/bases. The Keemun tea caddy is cherry, the little box in the middle (which I mainly made in order to try out the mitre shooting feature of the chest) is oak, lined with red oak. The tea caddy on the right is American black walnut.
Here's a picture of them all open:
There is a complete and fairly thorough build write-up of three of the four boxes (all but the cherry tea caddy, which followed much the same process as the walnut one) in the build log part of my website (the box builds start on page 130 of the 142 page, 1100 image WIP for the tool chest). Anyone bored enough to read a 142 page WIP? :LOL:
