Now that's one smart glasses case !stuffimade":3hc7qg5w said:I made this walnut glasses case, using leather as the hinge.
(i do have a build video if you are interested
stuffimade":1o0b90bc said:I made this walnut glasses case, using leather as the hinge.
(i do have a build video if you are interested![]()
Sawdust=manglitter":14rtroqy said:In the middle of making a carving mallet using a Lignum Vitae lawn bowls ball, tried the drill press with no luck (and was a bit dodgy) so last night I made my first down and dirty / quick donut chuck for boring a hole into the ball...
monkeybiter":3ni86bta said:Sawdust=manglitter":3ni86bta said:In the middle of making a carving mallet using a Lignum Vitae lawn bowls ball, tried the drill press with no luck (and was a bit dodgy) so last night I made my first down and dirty / quick donut chuck for boring a hole into the ball...
Looks good, better than my method; I force the ball against the chuck with a revolving centre then grip the ball in the jaws by one of the barely there grooves. It holds it firmly enough to turn a tenon on the tailstock end so I can turn it around and hold it properly.
Lons":3hlhlyd3 said:Removeable out table for my saw.
Made this so I could stash it out of the way also can be relocated quickly and easily in several positions along the main table just using a couple of bolts with wingnuts. i used a couple of lengths of 6mm x 50mm aluminium again from my stock of "treasures"![]()
Can't remember where the rollers came from, aquired many years ago I cut them up to suit.
Bob
Sawdust=manglitter":1ce3dhnd said:Going to be a shame to start using it!![]()
NazNomad":2de2obr0 said:![]()
Made this tacho for my lathe, just need to mount it now.
The digital control on mine only give a % of the max speed. It'll be nice to know what speed I'm actually turning stuff at.
