The blades I think youre looking for are here http://www.fine-tools.com/hobels.htm and or here http://www.fine-tools.com/eisen.htm
I could have sworn Steve had revealed the whole process on one of the forums, but I couldn't find it. However I did find this which suggests he's changed his habits. Unless he's changed again... :roll: :lol: It's noticeable that The Woodworker changed its advice sometime in the 30s to advising not to soak planes in oil, but rather just give them a quick coat of shellac. FWIW.Javier":1k3qnxtc said:Sorry, don't know what oil he used, but here's the link
http://showcase.netins.net/web/iabonsai/knight/building1.html
mr said:Looking at those Knight toolworks planes it appears that the blade is held in place by friction with the wedge only in the channel cut in the side plates. Is that the case? Other wooden planes Ive seen have had routed channels cut under the blades to take the screws holding chip breaker and blade in. Im also thinking about having a go at making a plane or two. I like the idea that a sole is not neccesary (call me cheap) and seeing as I have a fair amount of Ash offcuts was thinking of using that. quote]
The Krenov style planes use the routed channel for the chipbreaker screw.
I don't think I'd worry as much about wear or about using an exotic sole
on a jointer. You're not trying to make .001 shavings or trying to leave a
glassy surface. On the other hand if I could learn to make an adjustable mouth similar to the one on my Steve Knight pocket plane the sole would be irrelevant.I bought the plane with the wedge and grooved sides but he nows sells them with a brass screwcap instead and they seem to be more popular now.
I assume sealing was still considered a Good Thing, but the practice of soaking dropped out of favour.Scrit":5ch84x2s said:It still looks to me that sealing with BLO might not be such a bad idea
Alf":3fjbygtf said:I assume sealing was still considered a Good Thing, but the practice of soaking dropped out of favour.Scrit":3fjbygtf said:It still looks to me that sealing with BLO might not be such a bad idea
Cheers, Alf
I can see why anyone'd rather dump their plane in a bucket of oil and forget it, can't you? :lol:New beechwood planes should not be soaked in raw linseed oil. It is better to apply the oil with a rag pad and wipe over the plane twice a day for three weeks. Finish off with a few rubbers of orange french polish.
There is a section in Charles Haywood's book "Tools for Woodwork" 1946 (Page 31 in my 1949 reprint) where he said that modern opinion was that soaking caused distortion, and advised 2 coats of shellac over the top, sides and ends (not the sole therefore). Not sure when CH became editor of The Woodworker, but he had a big influence at the time.Alf":1jb89mo1 said:Okay, found the first reference in July 1938. I think just using shellac came later, but may have coincided with wartime restrictions so possibly just a sign of the times.
Cheers, Alf
