David C":12gjpa4e said:
Well Leonard Lee and countless others disagree with you.
Leonard's book has photos to prove it.
The quality of an edge is the product of the meeting of two surfaces.
If the back is rubbish the edge will be rubbish.
The "new sharpeners" are a figment of your feverish imagination.
David Charlesworth
I've noticed on irons that the only ones that have trouble getting a good edge (whether they are polished hard or not) are those that are out of whack enough that the finish stone cannot push a wire edge back toward the bevel when working the back.
I have experimented, as I said on other threads, I learned to sharpen from your video and followed the method to the dotted i's and crossed t's. But since then, I have prepared irons in planes and chisels while intentionally leaving the back a bit short as long as it was flat enough to affect the wire edge, and I haven't noticed a great deal of difference in the level of sharpness as long as the wire edge is completely removed.
That is, hypothetically if I left the relatively fine mill finish on a good piece of steel or a decently made vintage iron (as opposed to something like the new stanley irons with big mill marks on them), I don't know if someone could tell which plane has the black flattened if I prepared two.
It does require a fine abrasive to remove the wire edge without having the back worked.
I have seen other people write on it (bob rozaieski comes to mind). For a beginner, it's safer to polish the back to the edge, because there will be no judgement needed in knowing what's a problem and what's not a problem.
I may indulge myself later and make a video of this at some point, but I don't know if I want to encourage people who don't know enough yet about sharpening to start asserting that you don't need to polish the back of a tool (because that's what someone will say, even if only 3 people watch one of my videos).
On something like a straight razor, though, this would not be acceptable. I was not aware of just how sharp and properly prepared something like a straight razor needs to be until I started shaving with them. But polishing one side of the bevel, as long as the wire edge can be removed, will very easily shave hair and do something like take a 1/2 thousandth shaving. I won't be able to prove that until I make another plane, because I don't have an iron in any plane that hasn't had the back worked.
