PIR + Switch + LED Outdoor Lights
quintain
25 May 2007
West Cumbria
Hello
Can anyone supply a wiring diagram or YouTube link to connect the following:
4 x LED outdoor 50W lights
1 x outdoor Motion Sensor PIR
1 x switch (housed indoors) to operate all 4 x lights
using (probaly) 1.5mm T&E
All work would be carried out with full safety procedures.
Have you thought about solar LED lights? - no wiring required. There are quite a few good products around that have motion sensors with dwell/time-on settings. Yes you're reliant on light, not just sun, to power them but not usually an issue (even in the NW!)
I have fitted a number of cheap and expensive PIRs over the years. None have had issues with having a parallel switch to switch the lights on/off as well. I am not saying that every PIR will not have problems just that so far I have not found one.
Should we make it clear that a switch in parallel with the PIR sensor will only guarantee the lights be switched on?
If the sensor is triggered even with the switch off, the lights will illuminate. If you want a guaranteed off, the switch needs to be in series with the PIR sensor.
It's simple enough- but depending on the PIR concerned, some will need a neutral supply to the PIR others don't need one (hint the ones with a neutral tend to be more reliable with LED's)- plus another thing is some PIRs can be 'latched on' by 'rapidly turning on, then off, then on again- these need a switch in series BEFORE the PIR, while other PIR's don't have this feature, and will need a switch in parallel ACROSS the PIR instead to turn the LED's on manually... (to disable the PIR with this type ie turn the system off entirely, you need dual switches or a combination 'auto/off/manual' switch), most PIR's don't need a permanent supply- but a few do... so the circuit needed means knowing whats involved beforehand....
So its worthwhile choosing a particular PIR sensor beforehand, as the circuit used will depend on the PIR chosen...
Personally- Id use the ones you can trigger on by the 'on/off/on' style triggering to turn on, and run a neutral to the PIR (with switch in series before the PIR)- they are the easiest and most versatile arrangement imho...
This configuration uses a single 'normal' lightswitch, can be turned off entirely (switch off), can be used in 'PIR mode' (leave switch turned on) or manually turn lights on (switch on, then off, then on again rapidly- to turn lights off again from manual mode turn off the switch, to turn back into PIR mode wait a couple of seconds then turn back on again and leave on...)
Upvote for the solar option. I have a couple on the outside of my garage/workshop where we park the cars. They are perfect for lighting the back entry when we get home at night.
A couple of caveats: Not all solar products work well - though they are cheap so a mistake doesn't break the bank. Mine are on a south facing wall so get good sunlight. They provide very good lighting almost all of the time (very occasionally on dark days the lights aren't great if you get home very late). On the opposite side of the garage (the garden side) I've fitted a light with a separate panel which sits above the wall to get full sun. That works but the light isn't great (it means it is now rarely pitch black as I leave the garage and head into the garden, but the light isn't bright) and the PIR facility is very poor. it effectively provides low light through the early half of the night.
I have a light with a microwave sensor in the workshop loo, works through the wall surprisingly. Might be able to get a sensor on its own.
I used it because I didn`t want a switch in there so not sure how it would work with a switch.
Hello
Eacgh component would have had an accompanying sheet with details of installation and wiring details. In the absence of these it's worth noting that different makers use differing coloured wires so it would be wrong for anyone to offer asolution.
Solar power is good as long as it is located where it will get a good amount of light. I live in the valley, on the southern slope which means we don't get the sun from late autumn till early spring. My neighbour has a small, solar-powered, light on the drive but, in winter, it's no use. At best it flashes, at worst it comes on but dies seconds later.
I just bought a 10w LED outdoor PIR flood light from B&Q for £15.
It can be permanently switched on by switching the power off then back on in under 3 seconds.
It is restored to ‘normal’ PIR use by switching off then back on after 5secs.
Obviously if you switch it off, it’s permanently off.
I wouldn’t be surprised if you can find a standalone PIR sensor with the same functionality.
They are also usually supplied with wiring diagrams.
FWIW this is the 4th lamp in this location in 2 years. Interesting to see how long this one lasts. (The others were all bulkhead style).
Thats the type I recommended- mostly because they are even an easy 'retrofit' to an existing older manually switched light- uses the original switch and the PIR is just wired in series for the 'seperates' (in fact you can get just the sensor and even use the existing light/lights...)
This type of thing...
....another for solar.
We have a south facing light that works all year ...even in these northern climes.
As has been said, a set up can be purchased virtually ready to use.
Not for 200w worth of LED lights (well not at an affordable amount- they do exist- but cost a mint lol)
4 of these...
Umm... yeah...
I have used this Voltek range of security lighting controllers and PIR units for many years. They work very well.
https://www.voltek.co.uk/
Basically, the layout involves installing the lights with the necessary mains cabling. The control box is situated conveniently for the mains circuit; then the PIR(s) and keypad are wired up with 6 or 4 core alarm cable.
The keypad allows you to turn the lights on independently of the PIR and has an audible alarm when movement is detected by the PIR (this can be switched off)..
I see that Voltek supply a range of lights, but you can use the control system with any mains lighting.
