Need help with setting up Camvac Cgv386-5 90l
Simon A Wells
1 Jan 2025
Fort William
Hello!
I wondered if anyone could help me?
Just recieved a Camvac Cgv386-5 90l to help solve the dust problem in the workshop (HVLP unit is just struggling to deal with the fine dust).
Interestingly both the printed and online manual (3.5 July 2023) only refer to the wall mounted CGV286-3-WALL, not ideal as it does not have the inner large canvas bag listed as CVA386-20-101. The other record tools I have used have had simple, clear instructions. This set do not directly reference the set up for the product they come with, just the CGV286-3-WALL.
The printed instructions and the PDF instructions on the record power webisite make no clear reference to how and where to fit the large canvas 'bag', CVA386-20-101,to see the item please look at photo 1.
It would seem logical to fit into the collecter body to act as a filter and then shut the lid with the retaining strap handle, indeed if you look closely at some of the pictures in the instructions you can see if positioned that way. See photo 2 to see how I think, it should fit.
BUT and it is a big but, when I try to shut the retaining strap handle you have to apply a lot of force, a very large amount of force, comparable to say 40- 60kg'ish force, it works fine with out the bag, shuts easly with a suitable fit and force, similar to the 'blue expedition barrels' I use for work have the same system for closing.
These barrels are waterproof and sealed for work on white water etc, so when the shut you know that can keep out a very strong force of water. You know the 'blue expedition barrels are cross loaded etc when you have to put to much pressure on the retaining strap handle, the strap on the camvac feels similar i.e if I force it the single rivit will fail.
  • Is the bag in the right place?
  • Does your one need a huge amount of force?
  • Have I set it up correctly?
  • Is there a secret set of instructions I have missed?
With thanks,
Simon
    11.2 MB
    10.8 MB
    11.6 MB
Mine's an old 3 motor without the 'cyclonic' side entry. But you've got the basic idea right, I don't pull the cloth filter so far down the outside, I sit the elasticated bit just under the lip on the drum - having it that far down wouldn't give enough room for the motors on mine. The clips on mine take no real pressure, can't recall if they took more 20 or so years ago when I bought it but I am certain it was never hard work. I guess one cause might possibly be that the clips are trapping the filter sufficiently that it can't pull slack into the inside of the drum to allow sufficient clearance for the bottom of the motor as the lid clamps down. Probably not that at all, but worth eliminating.
I'd guess there will probably be a recommended motor orientation - on mine its obvious because the triangle of motors is offset to leave one side with a gap where the inlet comes in. Not sure what it would be for yours with the side inlet and what look like centralised motors.
