MIGNAL":2q6aa1ft said:http://www.crosscutsawyer.com/viewtopic.php?f=4&t=750
Yes, that is interesting!MIGNAL":2frmzlpo said:http://www.crosscutsawyer.com/viewtopic.php?f=4&t=750
I see where you coming from with this, but I think there are too many variables for a test like that to be meaningful. For example: User's: skill, psychology, preference, physical capabilities, past expierence. Saw's: Metallurgy, past treatment, overall age, sharpness, size, weight.... etc. There are just to many that you cannnot be certain about in an old saw alone (prove me wrong here) and thats not even including the huge influence the user has.Cheshirechappie":2vg1sge1 said:I still think the clincher will be if somebody produces two identical saws, one 'tensioned' and one not, and demonstrates a significant difference. Until then, it's all hot air.
Rhyolith":31kfsuvz said:I see where you coming from with this, but I think there are too many variables for a test like that to be meaningful. For example: User's: skill, psychology, preference, physical capabilities, past expierence. Saw's: Metallurgy, past treatment, overall age, sharpness, size, weight.... etc. There are just to many that you cannnot be certain about in an old saw alone (prove me wrong here) and thats not even including the huge influence the user has.Cheshirechappie":31kfsuvz said:I still think the clincher will be if somebody produces two identical saws, one 'tensioned' and one not, and demonstrates a significant difference. Until then, it's all hot air.
Plus as we don't actually know for certain what tensioning is yet, so how can we know one of the saws is tensioned (properly)? Particularly as all the examples seem to be 100 years old. So for me the clicher is definalty finding that out.
AndyT":j2spp7di said:I'm away from books again, but perhaps someone could check what our best saw historian, Simon Barley has to say on this. I think it's that final tensioning was only done on the top grade of saws, not on the second or third grade. That would fit with the collective idea that it's something not everyone would notice or appreciate.
Cheshirechappie":1foiz021 said:Rhyolith":1foiz021 said:I see where you coming from with this, but I think there are too many variables for a test like that to be meaningful. For example: User's: skill, psychology, preference, physical capabilities, past expierence. Saw's: Metallurgy, past treatment, overall age, sharpness, size, weight.... etc. There are just to many that you cannnot be certain about in an old saw alone (prove me wrong here) and thats not even including the huge influence the user has.Cheshirechappie":1foiz021 said:I still think the clincher will be if somebody produces two identical saws, one 'tensioned' and one not, and demonstrates a significant difference. Until then, it's all hot air.
Just to clarify, I didn't mean that somebody compares two vintage saws. What I meant is that somebody takes some new spring steel and makes two new saws from it, one 'tensioned' and one not. If there is a noticeable difference between the two in performance, or stiffness, or waviness of the toothline when it gets hot, or whatever, then it's clear that the 'tensioning' has done something. The maker would also know exactly what they had done differently with the two saws, and could describe the process, if not the exact metallurgical effect.
I suspect there may be a bit of 'suck it and see' involved in this. The links Mignal posted suggested some sort of rolling process rather than hammering, but the point of controlled testing is that you try something on one workpiece and compare with an identical workpiece not so treated to see what the effect is. It may be that quite a few controlled tests along these lines are needed to work out which is the most effective - or it may be that it demonstrates that none of them are particularly effective.
A fun project for somebody!
How about increased harness? As might be created by work-hardening the steel.Cheshirechappie":3etfnz8i said:Edit to add - the only way I can think of to make a sawblade stiffer (other than to make it a backsaw) is to make it from thicker material to start with. Stiffness of flat pieces of material is proportional to the cube of their thickness, so not much thicker makes it significantly stiffer. Conversely, not much thinner makes it significantly more flexible.
That's a good one, love it!Carl P":3ksnwalt said:as in 'the plural of anecdote is not data'.
ED65":1dzsr95v said:But actually, it can be.
ED65":1om23m6c said:Very late to this thread but just wanted to go back to something way back on the first page which might be critical.
How about increased harness? As might be created by work-hardening the steel.Cheshirechappie":1om23m6c said:Edit to add - the only way I can think of to make a sawblade stiffer (other than to make it a backsaw) is to make it from thicker material to start with. Stiffness of flat pieces of material is proportional to the cube of their thickness, so not much thicker makes it significantly stiffer. Conversely, not much thinner makes it significantly more flexible.
This is a well-understood process among traditional panel beaters and the steel used is quite similar. Edit: also with the making of steel drums. I can't imagine some hardening not occurring when hammering a saw, although the magnitude of the effect is likely a lot less since the changes in shape are so much more limited.
I agree incidentally that the use of the word tension might be a red herring, older written sources are a minefield when it comes to this sort of thing both with regard to modern technical usage of the same term and how it might be used in day-to-day speech. However, I'm not convinced there's no internal tension in a well-made traditional saw plate, sorry![]()
Rhyolith":o2cysnln said:I really really want to know what saw tensioning is now... as I am pretty much convinced it exists.
Can someone post a photo of a saw that is defiantly tensioned? I am just curious to see one (I do have a few old Dissitons, but I know little about them).
